SOURCE: I would push the prime button 3 or 4 times it starts then quiet
I took my carburetor off and blew it out with compressed air. Runs great now. Make sure to get all of it. Little screw on bottom has a hole in it too!
SOURCE: I need a part numnber for a coil for a Lawnboy
99-2916 may differ in appearance, but is a functional equivalent to prior parts including 684049.
Its 50+ dollars from Searspartsdirect.com
You might want to use both numbers and search Ebay for something cheaper!
SOURCE: How do I replace the primer bulb on my lawnboy
You must remove the engine cover (three torx screws) then you can pull the line off the plastic bulb disk and remove it from the cover by pushing the side clips.
Put silicone on the bulb disk and force the bulb on to the disk. I had to use a vice to hold the disk, it is a very tight fit. When you get the bulb on the disk, reinstall it in the engine cover and reattach the hoses. The gas tank hose will probably need to be pushed on to the carberator and the gas tank also. This is hard work but is the only way you can instal the bulb.
