Hi i have a Asus P5SD2-VM with windows 7 more than enough computing power but i cant get my resolution to reach 1440x900 which is my lcd's max pleaaase help!!!
Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero. hope this helps
SOURCE: I have an ASUS P5SD2-VM Mobo and i cant find the
You can download the drivers from ASUS WEB site. Select your model motherboard, and make sure you select the Windows XP or Vista version of the drivers that matches your Windows operating system. Click on this link: -
http://usa.asus.com/index.aspx
SOURCE: problem related to graphic driver
try different grapics card and add more memory to the machine
SOURCE: LCD not being detected
Restart computer -> Keep tapping on F8 key till safe mode option appears-> login using safe mode -> when login complete -> rightclick on my computer -> properties-> hardware tab -> Device Manager -> click on Sub-option "Display Adapters"-> Right click the adapter inside -> properties -> driver tab -> rollback drivers.
Follow instructions and restart and choose normal windows if asked.
If not successful, goto start -> all programs -> Accessories -> System tools, -> system resore -> choose restore to a previous... -> choose a date before the date you updated drivers. dont go 3-4 month, you might loose data. choose a closer date to the date you found the issue. follow the instructions.
restarts automatically and recovery screen comes. dont worry this is normal. when done, restart the system and see if resolution is alright.
get back to us with what has happened, we will support you further.
thanks, have a nice day....
Testimonial: "My system restore was not on. So I didn't take that route. I took the first solution and tried it out. It worked like a piece of cake. Thanks a ton!"
