Samsung Galaxy S Ii S2 I9100 16gb Unlocked Gsm Wi-fi Wifi Gps 8mp Android Phone Logo
Posted on Aug 11, 2017
Voice talk and voice command coming up with network error - please try again. How do i fix this? it works on wifi but not on 3g
When trying to use voice talk or voice command on 3g network. It works perfectly on wifi but when using 3g it comes up with a network error - please try again message. I have tried taking the battery and sim card out as well as checking my internet settings are all correct. I can still get onto the internet and everything else fine just not the voice talk or voice command. How can i fix this???
5 Related Answers
Anonymous
  • 1463 Answers
  • Posted on Nov 02, 2007
SOURCE: Samsung D900
this may help you set up the wap settings http://uk.samsungmobile.com/supports/configurephone/wapSetting.do?&menuIdBody=00000000000016&menuIdTop=00000000000003
riz.
A
Anonymous
  • Posted on Jun 23, 2008
SOURCE: samsung g600 network error for internet
Ive reset my phone by using #*7337# and all of a suddon the internet wont work. it says network error :<
Anonymous
  • Posted on Jul 24, 2008
SOURCE: help with my sync "network settings unavailable"
like i said in the above post, go into text messaging center and change the setting from empty to SMS
a w
  • Posted on Dec 03, 2008
SOURCE: Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Anonymous
  • Posted on Apr 08, 2011
SOURCE: I'm having problems with the
This sometimes happens, if you have just turned off your phone this will more o rless always happen. Just give it a couple of minutes and if this keeps on happening....turn off the phone take off the back and take out the battery and sim card. Leave it for a minute or two and then put them back in and turn on your phone. Then go back onto messages, it will still be happening, leave it for a minute or two and it should be absouletly fine, the sim is just taking a long time to load thats all, there is not really much you can do! I hope this helped (:
2answers
I have an dl 1168a and recently my wifi is not connecting my other tablt is connected just fine. Today when I went to try again none of the wifi networks are showing up. How do I fix this problem?
try this first
How to Fix Windows Socket Error
In order to understand what a Windows socket error is, and how to fix it, you first need to know the basics about windows socket. Windows socket is a specification in Windows. Its main function is to define how the network programs will communicate with each other, or how windows software access the network. A good example of these would be how an FTP client or a browser access the internet, that is, through windows socket.
Errors sometimes occur whenever the windows socket becomes corrupted during the removal or a spyware or adware. You are able to identify a windows socket error whenever the basic commands such as ipconfig does not work, or if you have absolutely no internet browsing capabilities.
The way to fix a windows socket error is to reset the entire Transmission Control Protocol/Internet Protocol (TCP/IP) on your Windows computer. You can do these by either using the command line, downloading a third party application and the like.
Windows Socket Error Command Line Repair
In order to reset the TCP/IP network stat, follow the steps below:
1.Go to the command prompt.
2.Type in the following command: netsh int ip reset resetlog.txt
3.This command will rewrite the required registry keys for the TCP/IP to function correctly. If this does not fix the problem, then proceed with the next solution.
Reset the Windows Socket Using netsh
2.Type in the following command: netsh winsock reset catalog
This command will reset the Windows socket to its default configuration. The risk here is that if you reset your Windows socket to default, several programs may be lost, and you might have to reinstall them. These would be programs like Google desktop search and other similar programs.
I have an innos mn8 Android smartphone. All day long I would try to download something or click to go to another page and it would say, network not available. Waiting on network. ..try again later. I'll...
Go to Settings and either look for a WiFi network connection or tap on 'More Networks' and then check the box next to the 'Mobile Data' menu pick. That's how it works on my Android phone (Samsung Galaxy S3).
Why is it that when ever I try to download games 50mb or higher on the Google play store I get an error (911). Please help I really want games like boom beach.
There is not one sure solution for these market related android errors and you'll have to try a bunch of fixes to fix these errors and chances are that the errors will come back and you'd have to repeat the process. The 911 error mostly occurs when you are trying to update your apps in the Google play store while connected to a faulty wifi network.
Method 1: Clear the Google Play store data
  • Go to Settings >> Manage Applications or Apps >> Open "All" tab
  • From the list of "All" apps >> Scroll Down and Select "Play Store" >> Select Force stop, Clear cache and Clear data
Method 2: If you are using a wifi connection that requires a webpage login, then your authentication has probably expired. Log in to the APN again via your android browser. Open Google Play store and run the app update again . If that didn't work the problem is with the wifi network itself.
Method 3: Simply switch to another Wifi network and run the update. The error 911 should disappear for the new Wifi network.
Method 4:
Use your mobile network data services instead of wifi. Turn wifi off and then turn your data on and now open your Google Play Store and download/update your apps or games. However, this method is only suited for apps and games that are small sized. For larger updates you should use your wifi network to save data charge.
I have a galaxy s3 and everytime I try going on to my wifi it says authentication error can any one help
It's probably because the password has been entered incorrectly.
In Wifi settings -> long click on the WiFi name, then click "Modify Network config", then enter the password again.
If that doesn't work, then check all the WiFi settings in that "Modify Network config" list of settings.
2helpful
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
MY IPHONE 3G IS NOT CONNECTING TO WIFI...IT SHOWS ERRORS AT WIFI
What kind of error? Are you trying to connect to a wifi connection encrypted with a password? If yes, you have to enter the correct password to be able to access the internet.
If the error still persists, try to reset network settings. It should fix all network related problems.
Just go to Settings > General then press Reset Network Settings
My Iphone 3G won't connect to home wifi after working well for months. In settings, it searches indef. for networks. 3G works fine. My husbands iphone works fine. Any suggestions?
you can try to set your wifi same as your husband's one, check the wep code and wifi shold be enabled.
try this and give feed back!
good luck
Error page printing after every job on Canon ImageClass 4000
STACKING IS A MEMMORY ISSUE OR THE POCESSOR CANNOT DO ANYMORE WORK UNTIL IT GET SERVICED.
OR
APPLE TALK SHOULD BE FORWARD AND EASY TO SETUP AND ON THE OTHERHAND YOU MAY NEED TO HAVE THE NETWORK SOFTWARE FOR APPLE CONFIGURATION, IT HAS BEEN ALWHILE SENCE I WORKED ON THE APPLE TALK, I CANNOT THINK OF THE SOFTWARE YOU NEED BUT THE OTHER OPTION IS NETWORKING IT IS GOOD OPTION IF AGAIN YOU HAVE THE PROPER SOFTWARE AND DRIVER TO HOOK IT UP TO A NETWORK THREW IBM/MAC COMPATABLE SYSTEM INTERCHAGEABLE SOFTWARE.
ALOT OF THIS HAS TO DO WITH THE NETWORKING AND SHARING PROGRAM, OTHER OPTIONS BEFORE YOU GO THREW ALL THE WORK IS CHECK OUT OTHER IDEAS, HETWORK ASSIST, CONTROL PANAL AGAIN, WIFI IS THE MAC WIFI CAPABILE, IS THE PRINT SETUP TO DO WIFI, THERE IS AN ADAPTER IS ABOUT 30.OO DOLLARS THAT YOU PUT THIS USB ADAPTER IN THE PRINTER CABLE CONNECTOR AND THE OTHER END IN THE SERVER OR COMPUTER AND THAN YOU ARE WIFI AND EVERYONE CAN SHARE AS LONG AS YOU SAY ITS OKAY TO SHARE IN THE NETWORK AND SHARING FOLDER
ROD
Error; Unable to load ipod itouch. Please try again or check your network settings.  Edge/3G or WiFi must be enabled to use backgrounds.
its saying to use that background it requires internet a wireless router so try not using that background
1helpful
Cannot Voice Dial from Bluetooth H700, Address book won't transfer
May not be the best one, but I just removed my battery and put it right back in and it works again.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
