SOURCE: Are any nutrients lost during the freeze-drying process?
None. During the freeze-drying process the product stays frozen keeping all nutrients intact.
Freeze-dried foods taste
almost the same as they did before with a minimal loss of taste or smell,
moreover the freeze-dried process doesn't shrink or deform the substance
therefore maintaining the structure of the substance.
Freeze-dried food cost
considerably much more than wet food because the costs of the freeze-dried
process and the expanses attached to it, including expansive machinery, energy
expanses, etc.
The secondary drying phase purpose is to remove the remaining
unfrozen water molecules. In this phase the temperature rises above 0, unlike
the primary phase, in order to break any
interactions that have formed between the water molecules and the frozen
material.
During this process the pressure is lowered and head is inserted
to the material in order to
make the water sublime. In this slow process, about 95 percent of the water is
sublimed. Furthermore the temperature during the primary drying phase is around
-50 Celsius.
The pretreatment phase includes concentrating the product, adding
components to increase stability. In many cases the decision to pretreat a
product is based on the theoretical knowledge on the freeze-drying process.
There are many method of pretreatment including freeze concentration, formulation to stabilize reactive products,
formulation to Increase the surface area etc.
There are four main
stages in the freeze-drying process, the pretreatment, the freezing, the primary
drying and the secondary drying phases.
The freeze-drying process was first used in World War 2 in order
to avoid spoiling serums sent from far way to treat wounded soldiers by
freezing it and keeping the serum molecule composition in the optimal state.
Yes there is, in freeze-drying process they use a cold temperature
and in dehydrated food they use warm temperature. In the freeze-frying process
the fresh foods are frozen first then the moisture removed in a vacuum chamber
and since the food remains frozen during the process, the food's cell structure
don't change.
