Added xbox wireless N networking adapter to my xbox and the light is green and stays green showing it has signal and i go through the steps and complete the Test Xbox Live Connection and my network status shows connected! and Live status is UP! but at that point i hit the B button on my controller and go to sign into xbox live and it then says offline! what do i need to do to get connected to and play on xbox live?
SOURCE: IP address Problem when connecting to xbox 360 live
i had the same problem buddy. The problem might be that you hacve another system on the wireless network that uses that same IP address. This can cause a conflict that will prevent the xbox from logging on. Try deactivating other systems on the network to see if thats the problem
SOURCE: Xbox live connection troubles
Not really sure whats going, but from what i have read it seems like there is a connection interference. make sure no is on the computer when you play live. and make sure everything is connected right.
SOURCE: cannot sign on to xbox live. Test Connection
an easy way to sort this out is to switch your internet off count to ten then switch it back on then try it it may have just picked up the connection wrong but had its staus as ok hope it helps
SOURCE: xbox 360 wireless
There should have been an instruction manual that came with your wireless adapter. But anyways, you may be connected to a password protected router and need to put in the password via the dashboard. I'm pretty sure you would goto network settings and then select the network you'd want to connect to.
SOURCE: when i test my xbox live connection the xbox 360
try to connect to another internet connection
