I plug in the port in my iPhone and it doesn't charge. I cleaned out the ports (I pretty sure I had done a thorough job of it), but still doesn't work. Tried resetting it but to no avail! Now it had died on me! PLEASE HELP!!!
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
SOURCE: My Iphone wont turn on
hold power button and home key as soon as u see apple logo let go of power button but keep holding home key this will put iphone in recovery mode then sync n recover
SOURCE: Iphone 3gs screen problem
If the problem is consistent in other windows besides strictly the keyboard it is possible that the capacitive touch panel is defective or has been damaged.
Testimonial: "That was my suspicion but was hoping for something simple . The is a store in Toronto that can repair it quite reasonably, considering. Thanks"
SOURCE: Shows fully charged (plug icon), but isn't taking a charge. A;ready tried reboot/restore.
Get a can of air and blow it into the 30-pin connector and headphone jack to clear the phone of dust and build-up. This should clear up the problem. I learned this from an Apple Store Genius Bar associate.
SOURCE: I dropped my iphone 3gs
Your iphone 3gs home button disturbed cause of falling, the charger pin n home screen button closely arranged...
Try to service your Iphone in a apple authorized service centre...
Dont try to service with unauthorized people...
SOURCE: iphone 3gs died today. Just
That happened to me once but i did a forced restart
Have you guys tried a forced restart?? if not try it, its very simple.
press and hold both your home and sleep mode buttons togeather until the phone starts.. let me know if it works.
