Question about Polycom SOUNDPOINT IP 501 SIP
PLANTRONICS Headphone won't work with IP 501 sip, polycome phone
Fairly straightforward.
I cannot get a peep out of my headphones.
It worked with a Cisco phone that I just stopped using yesterday, without fail.
I am plugged into the headset jack. (even tried the handset jack with the headpone... no avail).
phone works thru speaker and handset, but nothing through headphone
I assumed that a Plantronics headset would be compatible... maybe not.
thanks!
Dont plugged into the headset jack. Like Nortel, connect headset line with phone base unit in receiver jack and plugged your phone receiver wire into headset or plantronic base unit. This will work. I am sorry, my english is not too good but hope you understand it now. But the pully is not working properly with IP501..I mean it is not good to pickup IP501 receiver and put it back right place.
Posted on Apr 24, 2009
  • Nancy Labbe
    Nancy Labbe Mar 27, 2014
    You have the wrong wiring. Cisco and Polycom headset bottom cords are wired differently. Call 800-399-3224 for help
SOURCE:
Polycom IP 501 won't reset to default when using MAC address as password
If your phone isn't on a constant reboot cycle and can boot up, then go into Admin Setting and do a Format File System reset. NOTE: Only try this if you know how to download the software files onto the phone via FTP server. Once you download the latest software your phone should be almost as good as new.
Sep 19, 2012 | Polycom SoundPoint IP 501 IP Phone
Polcom phones stop ringing
go to this website and go to customer support www.polycom.com
Jun 24, 2008 | Polycom SoundPoint IP 501 IP Phone
Polycom 501 phone keeps trying to reboot itself. We rebooted manually a few times and get the same error message: 'Could not find boot server current configuation" Any ideas?
try to turn off the Polycom device. When you turn it back on, press Setup. from the options, select server then click edit. Then select the item Trivial FTP (that setup depends on your ISP), and type the IP address assigned to your network (example 192.168.90.90) then hit OK. click exit several times then press Save & reboot. If it did not work, let us know...
Jun 19, 2010 | Polycom SoundPoint IP 320 SIP IP Phone
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
Polycom ip501f error, application is not present
Make sure you have the latest BootROM and SIP config files for this polycom(sip.ld, sip.cfg, etc...) on your TFTP server. If you do not have this - download from here - http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip501.html
If you do not have a TFTP server, you can download one for free.
Dec 04, 2008 | Polycom SoundPoint IP 501 IP Phone
Making a Polycom SoundPoint 501 work on an Avaya IPO
As you have probably found, SIP phones are not supported until R5, which just came out.
Nov 11, 2008 | Polycom SoundPoint IP 501 IP Phone
I have a polycom 501 that is not working correctly. The speakerphone microphone is only recording static. This is as tested using the builtin diagnostics. If I record with the handset and then play with...
Best to contact your phone system provider, to determine if it is or if it still under warranty.These types of items are generally not user serviceable.
Dec 15, 2017 | Polycom SOUNDPOINT IP 501 SIP
I am unable to push the configuration files into polycom soundpoint ip 330 through tftpd
This means the phone's SIP application has been erased. You will need to download the SIP app and BootROM from the Polycom support page, host the files on a boot server, and then point the phone to this server from the server menu so the phone will reboot and download the files.
http://www.polycom.com/support/voice/soundpoint_ip/soundpoint_ip330_320.html
Aug 28, 2008 | Polycom SoundPoint 330 IP Phone
Polycom Soundpoint IP 501 - URL call is disabled
This in it's most basic description means that the phone is unable to register with the SIP server, most likely for lack of internet connectivity or a firewall blocking the packets.
If you've verified connectivity and opened the proper ports and the phone fails to initialize and still getting “URL Call Disabled” or all of the above parameters are correct, update the firmware for the router. This can usually be done within the router configuration. Then reboot in order, the cable modem or DSL, the router or switch, then the phone. This may solve the problem.
If still having the same issue, confirm in the router configuration for settings such as SIP proxy, gateway, or application layer or any configuration setting for SIP or VOIP. If any of these do exist, make sure they are turned off as these may only confuse or adversely affect many implementations.
Jan 08, 2008 | Polycom SoundPoint IP 501 IP Phone
I have 13 soundpoint ip 501 phones
R U USING XLITE OR ARE YOU USING ANY ASTRISK SEREVER... IT IS VERY EASY JUST GIVE ME THE INFORMATION..
Dec 05, 2007 | Polycom SOUNDPOINT IP 501 SIP
Computers & Internet Logo
347 people viewed this question
Top Polycom Computers & Internet Experts
Darren  Means
Darren Means
Tom Chichester
N8nNc
Are you a Polycom Computer and Internet Expert? Answer questions, earn points and help others
