I had purchased this shower head about 6 years ago, and the shower has to much water coming from it. It supose to have a water flow in it but still have that issue. Because my shower is glass and at the end it is open, I have to put towels at the end of the shower, does any one know if that adapter on the inside can be adjusted Thanks Doris
Reach out to Kohler direct. They may have an adapter that goes between the pipe and the shower head. I wonder if filling the shower head with polished garden pebbles would work?
https://www.us.kohler.com/us/Purist-Rite-Temp-pressure-balancing-shower-faucet-trim-with-cross-handle,-valve-not-included/productDetail/showering-pressure-balancing-valves-trim/423604.htm
Just turn the water valve down some
SOURCE: shower too hot
Hi sallypenn
I'm Harvey the Master Plumber.
Your question seems to be how to adjust the temperature of a shower valve?
I'm going to assume this is a single handle faucet. Most are adjustable under the handle. This is the responsibility of the installer but sometimes they forget and you can't get them back. Anyway this requires a little mechanical ability and a few tools.
First be sure to turn off the water to the faucet, then remove the handle (allen wrench or small screw driver). Most have a temp. adjustment ring right there. Simply pull out, rotate and replace. With some you have to remove the sleeve or bonnet under the handle to expose the adjustment fitting. Reasemble and turn on. It is not uncommon to have to do this two or three times before the customer is happy with the setting. The adjustment fittings usually don't have tenp. setting numbers to go by so it might take a few tries.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
SOURCE: Not enough hot water
Some higher end models do have an adjustment that is behind the face plate. You would have to remove the handle and the screws in the faceplate to expose them. If you have adjustments they will be located on the brass valve body facing you. You will need a flashlight and a flathead screwdriver to make the adjustment. If your model is not equipped with adjustments you could have a faulty valve stem. The stem is comprised of a rubber band like gasket that separates port holes into which the waters flow. There could be some piece of trash blocking the port not allowing adequate water from the hot side into the valve.Some valves stems are also able to be installed upside down causing the same issue as the ports do not rotate fully to allow adequate supply. However you say that you have adequate pressure on the hot side but not warm enough. There is another possibility also based on the way the shower supply was plumbed but there is no need to go into this unless this does not resolve your issue. I hope this is of assistance and thanks for using Fix Ya. Please let me know if I can be of further assistance.
SOURCE: My hot water in the shower is not as hot as from
Looking in at the screws from the shower side, first, check to see if you can feel any threads sticking out from either adjuster. Try to set them the same. Counter clockwise will give you more water from the pipe you adjust. If either of your pipes are smaller or filled with more corrosion than the sink pipes, you will have impared flow. If adjusting the valve doesn't give you the desired temperature, if you have the ball type valve, the seals need to be replaced. If you have the cartridge type valve, the cartridge needs to be replaced.
SOURCE: The water comes out of both the shower head and
I will have to assume this issue developed and was not present at first use after the initial installation.
There are generally only two reasons for your problem. The first is that the diverter mechanism is simply wearing out and/or broken. The second it that there is a foreign object preventing it from doing its job correctly. Either way the diverter must come out. I have provided a couple of links below that should help get it out.
Once out, put a wadded up towel over the end of the tub spout opening so as to prevent any water from coming out of it. Then, for just a moment, turn your shower on full and adjust your temperature from full cold to full hot. This process should dislodge any foreign matter and send it out the opening the diverter came out of and also will probably get you wet. I usually plug the tub so I can catch what, if anything, comes out. Having a second person holding a bowl over the diverter opening helps reduce the water splash.
Rinse off the diverter and reinstall it. Turn the shower on and see if there is any difference in how much water comes out the spout while in the shower mode. If nothing has changed then the next step is to replace the diverter.
The diverter assembly part number is A603819
http://www.danze.com/products/pdfs/D113000_ip.pdf
http://www.danze.com/products/pdfs/D500058T_ip.pdf
SOURCE: The water is too cold coming out of the Moen Adler
Turn the cold water feed down as low as possible to maintain pressure and increase the temp on the water heater.
