MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
it beeps twice and demand to press f1 to resume or f10 to setup. the problem is that the keyboard doesn't repond, it looks like keyboard is off. (almost everything is off I tried external keyboard through usb but no response niether)
I have the same problem with the same exact computer. My issue started on Dec 30th. I replaced the battery on the Motherboard, tried using an external keyboard and still no resolve. Any other solutions? If not, would it just be easier to buy a new laptop? I have the same problem with the same exact computer. My issue started on Dec 30th. I replaced the battery on the Motherboard, tried using an external keyboard and still no resolve. Any other solutions? If not, would it just be easier to buy a new laptop?
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help it beeps twice and demand to press f1 to resume or f10 to setup. the problem is that the keyboard doesn't repond, it looks like keyboard is off. (almost everything is off I tried external keyboard through usb but no response niether)
You can't post conmments that contain an email address.
Hi....
Actually beep sound indicates hardware error or BIOS error.
Don't press F10 while starting.
Let your laptop to start wait for 10min....
If it will not starts..........
Press F1(BIOS Settings for some pc F2 is Bois Setting)
If it will load BIOS.......... then your BIOS is OK
Then you need to change hard disk...
If not you need to change BIOS hardware(IF you i will tell you the way restore BIOS but it's very difficult task.It needs a trained person.)
It could be the memory modules (RAM). Get the information from those RAM sticks (manufacturer) and replace them with new ones to see if that solves the issue, if not then maybe the hard drive, and if it's neither of those, I hate to say it, but it sounds like a bad motherboard :(
It sounds like the RAM is either not compatable or is bad. Put the old RAM back in and try again. Also the V2000 and HP DV2000 is in recall for mother board problems.
if you have AMI, your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard. (more info on this click here)
for physical troubleshooting tips for laptop issues, please click this link.
Hi, and welcome to FixYa The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities. 1.New hardware has been recently installed. 2.Error or confliction with settings in CMOS. 3.CMOS battery is bad or failing. Solution: New hardware has been recently installed If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Error or confliction with settings in CMOS If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976. If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default. ·See our CMOS page for additional help and information with the CMOS. ·Additional information about getting into the CMOS / BIOS setup can be found on document CH000192. CMOS battery is bad or failing If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced. regards /Teis the Wiz - -> Vote "FixYa" :-)
Computer BIOS information and help
If the computer does not pass the POST, you will receive a combination of beeps indicating ... CH000301, Prompt to press F1/F2 each time computer boots.
I did, and it didn't help.
