Motorola Mobility HT820 Wireless / Cable Headset Logo
A
Anonymous Posted on Aug 08, 2012
Motorola HT280 connect to laptop - Motorola Mobility HT820 Wireless / Cable Headset
Need a power supply cord to my Panasonic SA-HT280. Where can I find/buy one?
find it on ebay or in store it will be cheaper online then the store
1helpful
Hi, how can i connect my motorola EX128 with laptop, is there any motorola phone tool is available ?
You can't connect a Motorola EX128 to a computer for Motorola did not make a PC suite for it.
However, you can connect your phone via Bluetooth technology and transfer files and make backups.
TENGO UN MOTOROLA HT280 Y NO LOGRO CONECTARLO A UN MOTO Z8, ME PIDE UN CODIGO,,,ME PODRIAN UYUDAR CON ESO..GRACIAS
El código de este auricular es '0000' (cuatro ceros). Si le falta la guia de uuario de su auricular, podrá descargala desde este sitio (solamente en inglés, inflelizmente). Un saludo,
Now in English, for other users out there: the passcode for this headset is '0000' (four zeros). By the way, if your headset's user guide happens to be missing, feel free to download it from this location. Regards, Carlos
2helpful
Internet connection
First download Motorola Phone tools on the computer.
Open the phone tools, click on internet - go to APN and type in aircelgprs and try getting connected. It should work.
Upload pix from motorola v3
IN MOTOROLA PHONES, THE USB CHARGING OPTION SO WHEN YOU PLUGIN TO PC IT WILL CHAGRE AND ALSO CONNECT THROUGH YOUR MOTOROLA PHONE DRIVERS IF YOU HAVE TO INSTALL. SO TRY TO CONNECT YOUR PHONE THROUGH USB WITH DRIVER AND TRY TO CONNECT, IT WILL BE AND THEN SHARE YOUR PICS WITH IT.
1helpful
Can I use a wireless router with motorola phone tools. What I want to do is to connect phone tools on a desktop and then add a wireless router (USB) so I can get wireless internet on my laptop.
Your question is somewhat confusing.
For clarification, there are two questions that you could be asking.
The first question would be: Can your phone be 'Tethered' to your laptop with either a Data Cable or Bluetooth to have internet on your laptop by using your phone as a modem? (No wireless router is needed to do this.)
The second question would be, that you have an internet connection on your desktop computer and want to use a wireless router to have internet on your laptop via WiFi. (In this case, your cell phone would not be needed.)
If the first question is what you are asking, to use your cell phone as a modem to provide internet access to your laptop - then the answer is, Yes. This is what you will need:
1) You'll need a Data Plan added to your regular cell phone service account.
2) To tether your laptop to your phone, your laptop will need to have either Bluetooth installed or you will need a USB Data cable.
Tip: If your laptop does not have Bluetooth installed, you can purchase any USB Bluetooth Doggle (on eBay for a couple of dollars) and plug it into one of the USB ports on your computer. Once plugged in, the doggle will automatically download the Bluetooth drivers to your laptop. Otherwise, you can use a USB Data cable to tether your phone to your laptop.
Note: Depending on the model number of your Motorola phone you may have to download the Data Cable Drivers onto your laptop.
If your phone is not one of the following phones then you can use Motorola Phone Tools. (Motorola OS, Motorola Linux OS, Motorola iDEN, Motorola Symbian/UIQ, Motorola Windows Mobile and Motorola i-mode Handsets. )
If you need the Motorola Phone tools (if your Motorola Phone Model was NOT one of the models I listed above)
Just click here::
http://bit.ly/1TN7A6
If your phone model is a (Motorola OS, Motorola Linux OS, Motorola iDEN, Motorola Symbian/UIQ, Motorola Windows Mobile or Motorola i-mode Handsets), you'll need to download the drivers for the Data Cable and install them on your laptop.
Click here:
Since you did not include which cellular provider you use, I cannot provide you with the information to manually set up your cellular internet connection.
Now, if the second question is the one you are asking, that you have internet on your desktop and want to use a wireless router to get internet on your laptop, here's what you'll need:
1) Connect a wireless router to your desktop.
2) Your laptop should have a small WiFi switch or button on the front or side of your laptop. This will need to be turned 'ON". (See your owners manual for your laptop to do this.)
If your laptop has WiFi installed, on your laptop go to START > (Look on the right side of the menu box and click on: 'Connect to' -- If you don't see, 'Connect to' in the menu you'll have to purchase a USB WiFi adapter. A good one is a D-Link DWL-G132 and can be purchased on eBay for about $10. Install the drivers for it first before plugging it in to your computer.
Click here to download the DWL-G132 drivers:
ftp://ftp.dlink.com/Wireless/dwlg132/Driver/dwlG132_drivers_130.zip
Once you download the drivers and plug in the DWL-G132 into one of your laptop's USB ports then click, START > Connect to > and select your wireless router.
H-300 for data transfer betyween laptops
if your laptop has bluetooth
then the headset will connect.
forsure
512 807-9336
i promise
Mobile internet access via laptop
yes its possible. first install motorola phone tools on your computer. then configure the phone setting/connection/data/fax connection. then connect the phone with usb cable. then click default profile-ok. it detects your phone. when the phone appears in the right down side of your pc,then click connect to the internet button. cofigure the connection according to your service provider and continue the process. any further infomation contact with me at 008801714731453.
11helpful
5answers
How to connect Motorola L7 mobile phone to internet using BSNL prepaid connection
Hai friends,
   U can use motorola l7 mobile phone use USB data cable and connect the gprs connection
2answers
My bluetooth headset Motorola HT280
Have you paired it with the Pocket PC yet? If you haven't.. press and hold the left-side M emblem for about 3 seconds until it starts blinking. This will put it in pairing mode. I'm not sure how to work Bluetooth on the Pocket PC, but wherever Bluetooth settings are, you need to turn on 'Find me' or something similar to that. Allow them to find each other, and they will ask for your approval, and then automatically pair. Hope that helps, goldfinger
Top Motorola Mobility Radio Communications Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
