SOURCE: 2000 impala, heater fan intermittent.
Could be a relay switch, check the fuse area and look for a larger square looking fuse or have it checked but get used one at wrecking yard,,real cheep there. Relays are fairly expensive new. About $20 bucks each. I've bought some at wreckers for just a few dollars. Easy to install, like a fuse.
Hope this helps.
SOURCE: why wont my heater or ac fan not blow in my car?
I'm having the same problem,and I've already checked the fuses. Is there some other possibility?
SOURCE: back driver door won't lock
Hello, this is caused by a bad door lock actuator. the door lock actuator is part of the door latch. the door latch will need to be replaced to correct this problem.
SOURCE: the car won't start; lights,
Check the starter and the starter relay or fuse. A client of mines car was doing the same thing, it ended up being two issues, the starter not working anymore, and a relay that was bad. If I am not mistaken everything should be labeled in the fuse box under the hood and will tell you where the fuse/ relay is for your vehicle
