This unit has been in service for quite a few years, but recently I've been turning it off via the rocker switch on the rear panel. Just yesterday, only the power light on the front lights up. The soft on/off switch will no longer turn on the display, nor do anything else. Nor does it respond to the IR remote. I opened the unit up, and found (6) fuses, 2 in the PSU bd (near the AC jack) and 4 in the "RSP1069 POWER" board. Checked with ohmmeter, all fuses ok. Anything else I can try, other than sending in for service? The dealer it was purchased from said it's probably not worth repairing, because it's only worth maybe $400 used, and it might cost $250-$400 to repair.
SOURCE: Rotel rx 1050...Not working
If you are not using the 12v trigger between pre-amp and power amp make sure that the trigger switch on the rear of the RB-1070 is set to off
SOURCE: Power amp r b
Check the headphone socket if it cuts out the speakers (normal use) when you plug the headphones in. If it doesn't and you have a switch to switch off the speakers when listening to headphones, check the switch. It may be physical damage or dirt causing the problem, or even loose soldering on the headphone socket. But the fact that headphones work shows the main amp is working. Also make certain the speakers are connected properly.
