I need an unlock code
Hi are you in need to unlock your Nokia 6300 mobile from network lock then visit prounlocking.com here they ask you the network name to which your mobile is locked and the imei number of your mobile .finally they deliver you codes to unlock your mobile.
SOURCE: unlock nokia 6300 sim
This code can't be calculated from IMEI. You need to go to a Service Center.
SOURCE: restriction code to unlock nokia 6300
You can contact your optus provider and ask them the UNLOCK CODE.
Other simple way is by using "universal sim" tool. Like X-SIM or other product.
Or you can use special device like JAF PLUS or BB5 BOX to unlock this fone by your self. Off course you need to be expert for using this tool, otherwise you can kill your fone.
br
To unlock mobile you have to give your IMEI number which is back side of the mobile,just remove the battery,you will got it.
NOKIA UNLOCK & OTHER CODES
You will need a nokia phone (only).
IT IS A CRIME TO DELETE/CLONE OR INSERT AN IMEI Number on a PHONE,
However you may if you own the phone you may pick a service provider sim's "free phone".
Any network this is for (NOKIA phones only),
*3370# Activate Enhanced Full Rate Codec (EFR) - Your phone uses the best sound quality but talk time is reduced my approx. 5%
#3370# Deactivate Enhanced Full Rate Codec (EFR)
*4720# Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
#4720# Deactivate Half Rate Codec.
*#0000# Displays your phones software version, 1st Line : Software
Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
*#9999# Phones software version if *#0000# does not work.
*#06# For checking the International Mobile Equipment Identity (IMEI
number). #pw+1234567890+1# Provider Lock Status. (use the "*" button to
obtain the "p,w" and "+" symbols).
#pw+1234567890+2# Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+3# Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
#pw+1234567890+4# SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
*#147# (vodafone) this lets you know who called you last.
*#1471# Last call (Only vodofone).
*#21# Allows you to check the number that "All Calls" are diverted to.
*#2640# Displays security code in use.
*#30# Lets you see the private number.
*#43# Allows you to check the "Call Waiting" status of your phone.
*#61# Allows you to check the number that "On No Reply" calls are diverted to.
*#62# Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
*#67# Allows you to check the number that "On Busy Calls" are diverted to.
*#67705646# Removes operator logo on 3310 & 3330.
*#73# Reset phone timers and game scores.
*#746025625# Displays the SIM Clock status, if your phone supports this
power saving feature "SIM Clock Stop Allowed", it means you will get
the best standby time possible.
*#7760# Manufactures code.
*#7780# Restore factory settings.
*#8110# Software version for the nokia 8110.
*#92702689# Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date,
4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To
exit this mode you need to switch your phone off then on again.
*#94870345123456789# Deactivate the PWM-Mem.
**21*number# Turn on "All Calls" diverting to the phone number entered.
**61*number# Turn on "No Reply" diverting to the phone number entered.
**67*number# Turn on "On Busy" diverting to the phone number entered.
12345 This is the default security code.
press and hold # Lets you switch between lines
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal
strength, better signal reception. It also help if u want to use GPRS
and the service is not responding or too slow. Phone battery will drain
faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart.
Increase battery life by 30% because phone receives less signal from
network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code.
Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol
up(arrow keys) for 3 seconds, should say pin code. Press C,then press *
message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
These codes should provide everything you need to mod your phone.
Mike.
SOURCE: unlock code for nokia 6300
wanna unlock ur mobile, here i found a site this is not free of cost but reliable , and i found this last week i used this nice...to unlock
http://www.mobile-unlocker.com/
1 - Switch on your Nokia 6300 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 6300.
3 - Compose #pw+CODE+1#.
4 - The Nokia 6300 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 6300 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 6300
