The GPS volume is barely audible when set to the maximum setting. I need to lower the radio volume to minimum and struggle to hear the commands. Any suggestions?
SOURCE: Intermittent, random, loud popping noises.
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
SOURCE: volume on my new nextar GPS X3-T isn't loud enough
You can buy an FM modulator at any wal-mart that will plug easily into the headphone port on the gps unit and play the sound out through the radio in your car. I had the same problem with my nextar gps but since I purchased the fm modulator it is plenty loud enough.
SOURCE: I can barely hear people speak.
To adjust the volume on the Nokia 2600 simply have someone call you and use the "arrow keys" to the left and right of the "menu" key. The volume will show as a line bar, the center of this bar is adequate for most people. When you hang up, the setting will remain.
Jerry
SOURCE: how to set start up volume control
I read another post that says that if turn on the unit and set the volume where you want it at startup, and then press in the volume knob until you hear it beep, that locks in the current volume as the startup volume. I just read this, so I haven't tried it myself yet. Good luck!
SOURCE: Can't adjust volume on hands free call (BlueTooth)
Try to adjust the volume on the phone while a conversation is going on, this may help in some cases...
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings, Thanks, JT
You can use the PREFERENCES menu option to change the volume of the voice instructions. Use 'Volume preferences' , with its sliding scale to set the required volume in increments of 5%.
The 'Test' function is a good way to get the volume right before starting your journey. You may also find it helpful to use 'Link volume to car speed', so that the voice instructions get louder as road noise increases and are at their quietest when you are stationary.
