I bought a le go technic 4x4 crawler a week ago, when I have done build the lego I found a problem, the crawler was not able to turn right, it is ok for turning left or moving forward/backward. I did troubleshooting, I switched the port between turning and moving at the IR receiver, then the result, I was able to turn left or right, but not able to moving backward, it was ok for moving forward. Please advice.....
SOURCE: Lego Island
Older programs will sometimes not work with Vista. This is likely the reason that Lego Island 2 (a 2001 game) will work a opposed to Lego Island (a 1997 game). There are a few things that you can try, though:
Give the icon the good ol' double click and see if she works. There's no guarantees that this will work with Vista since it is an older program, but this is where I would start.
I hope this helps!
SOURCE: I start LEGO Star Wars but then says lego starwars stop wrking
LEGO Star Wars II for PC requires the following minimum system requirements:
Operating System
Required: Windows 2000, XP, or Vista
Computer
Required: 100% DirectX 9.0c compatible computer
CPU
Required: Intel P3 1.0 GHz or AMD Athlon 1000 MHz
Recommended: Intel P4 2.0 GHz or AMD Athlon XP 2400+
Memory
Required: 256 MB RAM
Recommended: 512 MB RAM
Graphics Card
Required: 64 MB 3D Graphics card with Vertex and Pixel Shader (VS/PS) Capability
Recommended: 128 MB 3D Graphics card with Vertex and Pixel Shader (VS/PS) Capability
Sound Card
Required: 100% DirectX 9.0c compatible Audio Device
CD-ROM
Required: 8X Speed CD-ROM drive
Recommended: 16X Speed CD-ROM or DVD-ROM drive
Input Device
Required: Keyboard and mouse. Gamepad and joystick supported
Recommended: Gamepad
DirectX
Microsoft DirectX 9.0c (April 2006 Edition) is included on this CD. You will be prompted to install DirectX during the installation of this game if this or a more recent version is not already properly installed on your system.
NOTE: DirectX may require the "latest" updates for your operating system. This may also include the latest drivers for your motherboard, sound, and video hardware.
Installation: Installation requires 3.5 GB of free hard drive space. We recommend that you have an additional 500 MB of free space available after installing the game for the Windows swap/page file.
You must have local Administrator rights to properly install LEGO Star Wars II and update Dire
No other programs should be running in the background.
System resources should be at least 85% free.
To check this:
Press CTRL-ALT-DEL once, choose Task Manager, choose the Performance tab, and check CPU Usage.
There should be at least 500 MB of free hard disk space after installation.
If you experience performance issues when running LEGO Star Wars II, we recommend that adjust the following options in the Video Options menu:
Lower the video resolution.
Set Antialias to Off
If this option is set to Antialias from Control Panel, you will need to set your Antialiasing Setting to Application-Controlled in the Windows Display Properties for your specific graphics card.
Disable Bloom Effect.
Please close all other programs before running LEGO Star Wars II. This includes virus-scanning, word processing, and Internet programs. Simply disabling these programs will not always help, as the programs still use resources that are needed to run LEGO Star Wars II. If you experience problems completely closing programs that are running, consult the documentation for those individual programs. This is a common problem when trying to completely disable virus-scanning software.
SOURCE: My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
SOURCE: lost all saved data due to corrupt data
are you using a n5 homebrew card? if so its been corrupted and is irreversable. buy a new card
SOURCE: usb cable conected but not working for the lego mindstorms
is your NXT on? if not turn it onn
