Tape ejects after 4 sec. electronics of camera ok. does this also running external power
SOURCE: Canon MVX200 will not load dv tape
The "remove Tape" error message on Canon DV camcorders is a general message meaning something is not correct with the tape transport system. These are miniature precision mechanisms and It could be anything from dew sensors to head motor, capstan drive etc. If the cassette drawer closes OK with no tape inserted then the tape sensor/ end tape sensor is operating. With no tape inserted the head drum does not run when the drawer closes but it does with a tape present. Does the head drum start up when you load a tape or is there no noise at all? If the head runs then it is possible the capstan is not starting or is jammed. If the head does not run then the cure will be either extremely tedious and delicate or very expensive. These units do not dismantle easily so unless you have some experience with this, or are willing to take a risk, then I would not recommend it. However, without such action you may have to write-off the unit anyway. Canon's repair charge will exceed the camera's value unless it's still under warranty. Your best option would be to find a local repairer that is willing to look at it, but I wouldn't be too optimistic .To some, this error message is a major issue when deciding to buying canon dv cameras. However, they are great little cameras and treated kindly will give many hours of excellent service. Don't store the camera with tapes loaded. don't subject it to sudden temperature changes or excessive vibration. Store it in a dry protected atmosphere and refrain from taking it onto the beach (salt AND sand !!!!) when on holiday etc.
SOURCE: Error Message Reconect Power even if power is connected
It sounds like the tape door is out of alignment, causing stress on the tape and the inside mechanical system. Requires a visit to the service shop.
SOURCE: Cannot insert tape into canon MV800. Always ejects
Hi Everyone,
our MV800 was doing the the same so i "accidentally" dropped it (i got a bit frustrated and it was out of warranty) and now it works fine. please note it dropped about half a meter on carpeted floor while it was off.
Hope this helps
SOURCE: Canon zr300 ejects tapes
Hi Everyone,
Hope this helps
SOURCE: canon camrecorder will not load cassettes take
Believe it or not, but I found a possible solution for that in another forum. The suggestion was, to let the camera drop from about 0,5 m height onto the floor. Make sure, that there is a carpet underneath, which prevents the camera from severe damage.
This is no joke - I have let it drop once and the cassette was loaded and everything worked fine. There might have been a sensor problem or a little hickup in the mechanic.
Try it on your own risk - but what do you have to loose ? I wanted to sell the camera as broken on ebay, but now, I have a running camera again.
