After the old hard drive stopped working, i put in a toshiba mk8007gah hdd, which i believe is compatible. i've managed to format it (FAT32) on my laptop via usb, transfer files, check the disc, all seems fine. BUT the drive will not ever boot up in the player, either using the original iriver firmware v.1.29 (CHECK HDD CONNECTION error), or the Rockbox system which previously worked (variety of ATA errors). i cannot reinstall iriver firmware using player's General menu. what am i doing wrong/not doing. apologies, i'm not v.technical
There are websites that offer data recovery from a failed drive. That would be your only option here.
Lost Data Call us now
Hard Drive Recovery Services SALVAGEDATA Recovery
SOURCE: Iriver says ''Check HDD Connection'' at initial boot up--
if you know some one with the same iriver...you can copy thier software (not music) onto you pc / laptop....disconnect & plug your iriver up...now you can format your iriver..copy the software onto it...its like starting fresh now.......but if no one is around w/ an iriver..you will have just purchase another one ...(if purchase hard drive you will still need the software)...
http://shop.ebay.com/items/?_nkw=TOSHIBA+%28hard+drive%29+1.8&_sacat=0&_trksid=p3286.m270.l1313&_odkw=TOSHIBA+MK3006GAL+30GB&_osacat=0
