SOURCE: Locking my g900 sony ericsson with a pin code
Go to the 'Main Menu' > 'Settings' > 'Security' > 'Locks'
In the decide whether you like to set up a Security Code upon opening the phone.
If you want so, under the 'Phone Lock' category choose 'At power On'
If you want it to lock automatically when you're not using it,
check the box beside 'Inactivity Lock'
When your prompted to put a Security code upon doing those,
type in '0000', it is the default Security Code for this unit.
SOURCE: how to access internet using wifi for g900 sony
1.Activate wlan
2.Scan -search for WIFI
3.Those without lock u can connect to(the others need password more often a wep KEY)
4.Some of them requir to pay (so it is not locked but in order to have internet access you need to pay)
5.connect (if the wifi use dhcp it sends to your mobile IP address + gateway+ dns)
6.You check your ip anf if it is something like 192.168.x.x it should be ok
7.you try to open internet from the menu.
Good luck.
SOURCE: Dark screen on G900
go to mobile service center clean and dry RAM pins now working with out problems. only one or two months take care....
SOURCE: I cannot find how to change language frm swedish to english
Assuming that all the text is inSwedish and you can't understand it then follow these instructions. Using 'PANEL' button(X at bottom left) on front facia select the top left Panel (black screen with XPERIA written accross the bottom) now select windows logo(top Left)at the bottom of the list should be a 'blue circle with a question mark in the middle of it', immediatley above this should be the 'Settings' folder - select this. You should now have icons(pictures) with 3 'Tabs' along the bottom of the page - select the middle one ( this should be 'system') now look for a Globe (picture of the World) this should be 'Regional Settings' - select this. From the drop down menu select 'English' and whatever regional dialect you want, when you have done this tap top right corner, this should be OK until you are back at the Main Panel, now shut down and then restart X1, you should now have everything in English. Good luck.
SOURCE: calibrate
go to main menu> control panel> general> setup wizard
click next untill pencabration comes
