My Frigidaire Dishwasher is not spraying water from the bottom. It comes in from the side and seems to be draining fine, but it doesnt seem to be shooting any water on the dishes. The dishwasher is making noise like it is trying to work, but for some reason is not.
SOURCE: Water not draining
I have the same problem, I understand that a little water won't be a problem, Question? about how many gallons of water are distributed throughout a cycle or cycles of wash.
SOURCE: Dishes not being cleaned properly - large portion of tablet still remaining in the bottom
I have a 4114 and the problem was not enough water entering the washer. You can check by adding extra water (kettle full) to the washer just after start. ( opening the door just suspends the cycle) If your dishes clean well then you will need to adjust the pressure level switch to allow more water in. There is an adjustment screw on the switch which needs to be turned 1/4- 1/2 a turn. This puts more tension on the spring so more water needs to enter before the switch is activated. On the 4114 the switch has 2 adjusters. It is the taller of the 2 that require adjusting. Do little turns until the water level just covers the filters.
SOURCE: have a trouble: dish-washer will not drain.
I just moved into a new house and builder had provided a dish washer drain just below my kitchen drain line.
DIsh washer install was done by me, every thing worked out OK except dish washer would not drain after a wash cycle.
Cause: drain provided by builder was blocked and needed a circular small cut before mounting drain hose over it.
SOURCE: frigidaire dishwasher - no heat coming on to dry the dishes
Did you ever learn why the heat was not drying dishes? We have the same problem.
SOURCE: My Frigidaire Prof series dishwasher is leaving a
Check your heating element..
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
