Check the speaker first. Check if there is any sound output comes from the audio out terminals at the back of the TV, by connecting them to any external audio out devices; such as an amplifier or so. If there is audio output comes from the external source such connected, and no audio output from the TV; since the speakers are good, the fault is with the audio output section circuit inside the TV. If there is no audio output from the external sources too, the fault is with the audio processing section circuit at the main board. If this is the case, main board is faulty, and should be replaced.
Testimonial: "Very detailed solution, thanks :D"
SOURCE: kdl 32v4000
Two
blinks - B+ over current protection (OCP), unit goes to the standby mode then
displays the 2 blink fault. Could be a short in the power supply of any of the
circuits.
Malfunction of 5V line
(Voltage Supply to FE, etc) please check 5v power supply other wise change
BG1TW MOUNT (KDL-32V4000)
main system board
