SOURCE: touchflo (process com.htc.launcher) has stopped unexplectedlu
All i did was take out my SD card and wait 15 seconds then put it back in the phone. I did not see the process com.htc.launcher error anymore.
SOURCE: I get a sorry message when ever i open the
Have you tried to restart your phone? Try turning it off and then back, and see if that fixes it.
Have you installed any apps on your phone? See if uninstalling some of these apps might help your problem.
It would help to know what you have done with your phone since this error has come up (have you rooted the phone, installed a theme, apps, what settings you might have changed, did it work previously)
SOURCE: says the application HTC sense(process
Welcome to Fixya. To fix the issue you need to reset the phone to its factory settings
To reset the phone using buttons:
With the phone turned off, press and hold down the volume down and send buttons, then press the end/power button.
You will see 3 Android images at the bottom of the screen.
Follow the instructions onscreen to reset your phone.
Tip: If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone.
If you have questions please let me know. Thanks for using Fixya
