Citizen EcoDrive Calibre 3100 BT000007E Watch Logo
DAVID TOWNSEND Posted on Aug 07, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
HOW TO SET DATE - Citizen EcoDrive Calibre 3100 BT000007E Watch
Level 3:
  • Citizen Master 18,429 Answers
  • Posted on Aug 08, 2012
Citizen Master
Level 3:
Answers
18429
Questions
Helped
1405213
Points
62248
I have a omax quartz watch with day and date how do i set the day and date
How to set date and day in omax watch simple steps
May 23, 2012 • Watches
2helpful
Do you have directions for armitron mens pro sport watch 49/1000
Hi robinmsavage,
I will be glad to help you with your concern regarding your Armitron Wristwatch, what exactly would you be experiencing? cause I only put info on how to set time and date on the Watch.
Please see below steps:
  • Your Armitron Watch will have Four Button on the side of the watches rim.
  • Button on the upper Left is MODE.
  • Button on the lower Left is LIGHT.
  • Button on the upper right is DATE.
  • Button on the lower right is Alarm.
See Steps below:
*Setting the time*
  • Press and Hold down the Mode Button til the Hours flash
  • Then push Alarm Button to set the Hours
  • Press and Hold down the Date Button till the Minutes flash, then push Alarm Button to set the minutes
  • After setting the minutes on your watch, Press Date till you get the month flashing push Alarm to set the month
  • Press the Date again till the Date flashes, then push Alarm to set date
  • Press the Date again till the Date on your watch flashes, then push Alarm to set the date
  • After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
Thank you for choosing Fixya,
mvincentc
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
4helpful
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
7helpful
How to set an Armitron watch. Can't set the days correctly.
mcdevito75 here, The stem has 2 positions, Carefully slip a fingernail under the stem and lift, it may take a few trys to get used to it, in this first position you should be able to set the DATE very easily and Maybe the DAY of the wwek also, turn the stem 1 way to change the DATE and the other way For the DAY of the week., Let"s figure you can only set the DATE in this first position, First thig to do is set the DAY of the week, go thru the watches 24 hour cycle and set the DAY to 1 DAY before the DAY you need, now in that first position of the stem, set the DATE to 1 DATE before the DATE you need, now in the 2nd position we all know pull the stem out to set the time of day, go thru the 24 hour cycle to bring up the DAY of the week and DATE you need. Now your watch is set and will change on tome at around mid-nite.
Jul 21, 2010 • Watches
3helpful
Adjusting day/date on a self winding Seiko, 7S2GB
mcdevito75 here, Your stem has 1 positions to set the date easily without haveing to cycle the watch 60 times. First pull the stem out to set the day, set the day 1 day before the day you want, next, push the crown back in, NOW! Slip a finger nail just under the crown from the back as there is more room, it may take some practice so be patiernt and gently, gently lift the crown to it"s first position, once in it"s first position turn the stem and see the DATE change, set the DATE to 1 DATE before the DATE you want, NOW pull the stem out to set the day date and time of day. Your watch is set and the day date will change on time, a little past mid nite.
54helpful
2answers
Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
1helpful
Set date
hello..this is not abig problem..just a sincronization one...ususlly I set the date around the 12 oclock in the night..the 0 hour..its easier...if you dont want to do this...well..then just count the hours ..remember you have the 24 hours /day..and remember the date is changing in the night around 12 oclock..
for instance...lets say..now you want to set the date..you count the hours until tonight at 12...you put it lets say...with 12 hours back..and wait the change in the midnight..
the easier way is to set it at midnight
oh...by the way..I saw watches which change the date around 2 oclock in the night..but this is a very small %...99% are set to do it at 12..
good luck
2helpful
3answers
Setting the day and date
i am scared of putting to much force turning the crown
It is very hard or stiff ND CAN'T LIFT CROWN TO BR ABLE TO SET DATE AND TIME
9helpful
How to change the date on cartier santos chronograph watch
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
Top Citizen Watches Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Citizen Watch Expert? Answer questions, earn points and help others
