The supporting frames of the wheel section are stuck in an open position so that the handle bar section and struts (joining the central hub) form nearly a right angle to the section of frame carrying the wheels. The central hub of the whole frame mechanism seems to have "locked" the two frames into this right angle position, when normally it will release the frames to fold back into an overall flat position, (in normal operation by pushing the sliding finger release on each side of the handle bar). Is there any adjustment, release or repair I can carry out?
I would add that the locked position (on trying to release the frame with the finger sliders) appears to be only on the hand side of the hub mechanism, but the result is still a locked position between the two framesI would add that the locked position (on trying to release the frame with the finger sliders) appears to be only on the hand side of the hub mechanism, but the result is still a locked position between the two frames
You can't post conmments that contain an email address.
Hi, i'm sure you have already figured this out but the frame will not lock into postiton until the carrycot or seat unit is attached to the frame. Once this is attahced the frame should lock.
It is inside the transmission , side cover . Need to take driver side wheel off an maybe the inner fender well to see it .
Removal Procedure
Remove the case side cover. Refer to Control Valve Body Cover Replacement .
Disconnect the transaxle wiring harness.
Alot of steps involved to replace it .
Removal Procedure
Remove the throttle body air inlet duct. Refer to Air Cleaner Element Replacement .
Remove the engine mount struts. Refer to Engine Mount Strut Replacement - Left Side and Engine Mount Strut Replacement - Right Side .
Remove the wiper module cover.
Disconnect the 20-way electrical connector at the transaxle.
Remove the shift cable bracket from the transaxle. Refer to Range Selector Lever Cable Bracket Replacement .
Install the engine support fixture and support the engine/transaxle assembly. Refer to Engine Support Fixture .
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Remove the left front tire and wheel. Refer to Tire and Wheel Removal and Installation .
Disconnect the left wheel speed sensor harness connector (1).
Remove the left engine splash shield. Refer to Engine Splash Shield Replacement .
Remove both stabilizer shaft links from the lower control arms. Refer to Stabilizer Shaft Link Replacement .
Remove the wheel speed sensor harness from the control arm (1).
Remove the left lower ball joint from the left steering knuckle. Refer to Steering Knuckle Replacement .
Remove the left drive axle from the transaxle. Refer to Front Wheel Drive Shaft Replacement .
Reposition and secure the drive axle.
Remove the heat shield bolts from the frame. Refer to Steering Gear Heat Shield Replacement .
Remove the steering gear-to-frame bolts and secure the steering gear.
Support the left side of the frame with a utility stand.
Remove the transaxle mount lower nuts only. Refer to Transmission Mount Replacement .
Loosen the engine mount lower nuts. Refer to Engine Mount Replacement - Right Side .
Remove the air deflector. Refer to Radiator Air Baffle Assemblies and Deflectors .
Remove only the left side frame bolts. DO NOT LOOSEN the right side frame-to-body bolts. Refer to Front Frame Replacement .
Use the utility stand in order to lower the left side of the frame.
Position a drain pan under the transaxle.
Remove the utility stand and lower the vehicle.
Loosen the right engine support bolts. Refer to Engine Mount Replacement - Right Side .
Raise the vehicle.
Remove the transaxle mount bracket. Refer to Transmission Mount Bracket Replacement .
Remove the transaxle wiring harness connectors.
(391) Automatic Transmission Fluid Temperature (TFT) Sensor
Inside the transmission behind side cover
Removal Procedure
Important: Lock steering wheel in centered position with wheels straight ahead.
Remove the engine dress cover.
Remove the air cleaner intake duct. Refer to Air Cleaner Inlet Duct Replacement in Engine Controls - 3.1L or Air Cleaner Inlet Duct Replacement in Engine Controls - 3.8L.
Remove the engine mount struts. Refer to Engine Mount Strut Replacement in Engine Mechanical - 3.1L or Engine Mount Strut Replacement - Right Side and Engine Mount Strut Replacement - Left Side in Engine Mechanical - 3.8L.
Important: For supercharged engines, remove the throttle cable bracket.
Disconnect the shift cable bracket.
Remove the transaxle top side cover bolt.
Install the engine support fixture. Refer to Engine Support Fixture in Engine Mechanical - 3.1L or Engine Support Fixture in Engine Mechanical - 3.8L.
Disconnect the transmission wiring harness connector.
Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the left front tire and wheel assembly. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Remove the left inner splash shield 3 push pins.
Loosen the wheel speed sensor harness from the 5 retainers at the cradle.
Remove the transmission support to cradle nuts only. Refer to Transmission Mount Replacement .
Raise the vehicle.
Remove the front splash shield 5 bolts.
Loosen the engine mount lower nuts. Refer to Engine Mount Bracket Replacement in Engine Mechanical - 3.1L or Engine Mount and Bracket Replacement in Engine Mechanical - 3.8L.
Remove the stabilizer bolts and reposition the stabilizer.
Remove the steering gear cradle bolts, then support gear before lowering cradle.
Support the left side of the frame with a jackstand.
Remove the left side frame bolts. DO NOT loosen the right front or the right rear frame bolts. Refer to Frame Replacement in Frame and Underbody.
Remove the left ball joint from the steering knuckle.
Position the drain pan under the transaxle.
Remove the left drive axle from the transaxle. Refer to Wheel Drive Shaft Replacement in Drive Axle.
Secure the drive axle to the steering knuckle/strut.
Adjust the jackstand to lower the left side of the frame until it hangs free. Remove jack stand.
Lower vehicle to access engine support fixture.
Lower the engine/transmission assembly with the engine support fixture to gain access to remaining side cover bolts.
If replacing the side cover, remove 4 engine mount bracket bolts.
Remove the harness retainer.
Raise vehicle to access side cover bolts.
Remove the case side cover bolts (56-58).
Remove the case side cover pan (53).
Remove the case side cover gasket (54).
Clean the case.
Clean the side cover gasket mating surfaces.
Disconnect the wiring harness assembly from the fluid temperature sensor (391).
Remove the fluid temperature sensor (391).
Installation Procedure
Install the fluid temperature sensor (391).
Connect the wiring harness assembly to the with fluid temperature sensor (391).
Install the case side cover. Refer to Control Valve Body Cover Replacement .
Important: It is recommended that transmission adaptive pressure (TAP) information be reset. Resetting the TAP values using a scan tool will erase all learned values in all cells. As a result, The ECM, PCM or TCM will need to relearn TAP values. Transmission performance may be affected as new TAP values are learned.
Reset the TAP values. Refer to Transmission Adaptive Functions .
you broke that spring, really< or is this another job? do say job .
no year, wow, that does make it hard,
as all books are indexed by year, first.
so i cant get off the dime. (parked here)
ill guess and its a 2000.
car has struts.
alldata.com (DIY)
I never do change, just remove. sorry, login and read it all.
Before servicing the vehicle, refer to the Precautions section.
Support the vehicle at the frame with a hoist or jackstand.
Support the control arm with a floor jack.
Remove or disconnect the following:
Front wheel
Brake caliper and rotor
Locking hub or drive flange, if equipped
Axle shaft snapring and thrust washer, if equipped
Thank you by your request, I will help you inmediately.
1) Unpack the carton. Place Main frame and Running track on a flat level floor. Attach the post left and right onto the Main frame withthe Screw.
2)Attach the STABILIZER Stand with the post lef and right before mentioned 1) onto the main frame annd tightly secured with Screw/Nut.
3) Raise UP the post Left +Right mentioned Before in the section 1)
4) Inser the Handle Bar left +Right in the front Handle bar, then onto the post Left and Right mentioned into the section 1)
5) Put the computer unit onto the fron Handle Bar with Screw.
6) Raise the Main Frame and Running Track up, attach adjustable Rod with Screw Nut and lik Stabilizer stand tightly secure with screw nut. Warning: On folding up the running track, do make sure que the pin lock knob are porperly enganged and securely tghten to prevent accident. To unfold, Pin lock simply loose to pull out Knob and gently lower the Running Track.and Ready.
Section 04-01: Suspension and Wheel Hubs, Front
1996 Windstar Workshop Manual
REMOVAL AND INSTALLATION
Stabilizer Bar
Removal
Raise and support the vehicle. Refer to Section 00-02 .
Support vehicle with hoist or safety stands behind front sub-frame (5C145).
CAUTION: To avoid damage to the 6 mm drive hole in the front stabilizer bar link ball stud, do not use an Allen wrench to break loose or tighten or final tighten the front stabilizer bar link-to-shock absorber nut.
Using care not to damage the front stabilizer bar link ball stud seal, remove the RH and LH front stabilizer bar link-to-front shock absorber nut.
Using care not to damage the front stabilizer ball link stud seal, remove the RH and LH front stabilizer bar link-to-front stabilizer bar nut.
CAUTION: Use extreme care not to damage the ball joint boot.
With another set of support safety stands under front sub-frame, remove two rear sub-frame retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
Remove front stabilizer bar bracket bolts, stabilizer bar brackets, stabilizer bar bracket insulators and front stabilizer bar (5482) as required.
Installation
Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar bracket insulator installation position.
Lubricate inside diameter of new stabilizer bar bracket insulator with Rubber Suspension Insulator Lube E25Y-19553-A meeting Ford specification ESF-M99B112-A or equivalent. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber stabilizer bar bracket insulators.
Install new stabilizer bar bracket insulators onto front stabilizer bar and position them in approximate location.
Install stabilizer bar bracket on stabilizer bar bracket insulators and install new bolts. Tighten to 55-63 Nm (40-46 lb-ft).
Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Tighten to 115-132 Nm (85-97 lb-ft).
Install front stabilizer bar link (5K483) to front shock absorber. Use care not to damage link ball joint boot seal.
Install a new front stabilizer bar link-to-shock absorber nut. Tighten to 90-100 Nm (66-74 lb-ft).
Sounds like the handle bar extender mechanism has broken internally and the Gas strut is faulty. This happened to mine. Both parts are readily available from Dorel UK 01842 763 281 (Mon – Fri, 8:30 am to 4:30 pm). They are the sole supplier of parts for Quinny. However, the Gas Strut is a pressurised mechanism and has to be replaced by Dorel. You will need to speak with them and arrange for the frame of the buggy to be sent to them (at your cost if out of warranty) and they will replace whatever parts you need plus do a full service.
then, there are 2 knob, sticking out of the sides of the frame, about 6 inches below the handle, from the normal pushing position, hook yr fingers round them and slide them up the frame towards the handle
the handle will drop, then just up the frame from the cross bar under where the set is.
easy once you know how
if it still don't work, go to your local park and accost the nearest person with a bugaboo and ask for some help - there'll be hundreds of them!
1996 Taurus, Sable Workshop Manual
Stabilizer Bar
Removal
Raise vehicle on a hoist. Refer to Section 00-02 .
CAUTION: Use extreme care not to damage boot seal. Do not use power tools to tighten nut, or bearing and seal damage will result. Install nut using hex hold feature to prevent the stud from rotating.
Remove and discard nuts retaining stabilizer bar link (5K484) assembly to front stabilizer bar (5482) and front shock absorber (18124) with an 8 mm closed-end wrench and an 18 mm open-end wrench.
Remove nuts retaining steering gear (3504) to front sub-frame, and move steering gear off the front sub-frame.
With another set of support safety stands under front sub-frame, remove two rear subframe retaining bolts. Lower rear of the front sub-frame to obtain access to stabilizer bar brackets (5486).
Remove front stabilizer bar U-bracket bolts and replacestabilizer bar brackets and/or front stabilizer bar as required. Discard lower suspension arm stabilizer bar insulator (5493) and bolts.
Installation
Clean front stabilizer bar to remove dirt and contamination in area of stabilizer bar insulator installation position.
Lubricate inside diameter of new lower suspension arm stabilizer bar insulator with Rubber Suspension Insulator Lube E25Y-19553-A or equivalent meeting Ford specification ESF-M99B112-A. Do not use any mineral or petroleum based lubricants as they will deteriorate the rubber lower suspension arm stabilizer bar insulators.
Install new lower suspension arm stabilizer bar insulators onto front stabilizer bar and position them in approximate location.
Install stabilizer bar bracket on front sub-frames and install new bolts. Tighten to 30-40 Nm (22-29 lb-ft).
Raise front sub-frame and install new front sub-frame-to-body retaining bolts. Position steering gear onto front sub-frame and install retaining nuts. Tighten to 115-135 Nm (85-99 lb-ft).
Install stabilizer bar link to front shock absorber and to front stabilizer bar, making sure that the stabilizer bar link is properly positioned. The letters "Top LH" and "Top RH" are moulded into the stabilizer bar link for correct assembly to the front shock absorber strut.
Install new nuts and secure stabilizer bar link assembly to front stabilizer bar and front shock absorber. Tighten to 77-103 Nm (57-75 lb-ft) at front shock absorber strut and 47-63 Nm (35-46 lb-ft) at front stabilizer bar.
