I have used an 8 GB micro SD card with my camera to record the recordings on. I had used up almost 7.5 GB of data on the card, I then took another video from my camera. But now when i connect the micro SD card to my computer, it detects the external drive (card) but is not able to display any contents. It says that the used space is 0 bytes and the free space is 0 bytes. Has anyone experienced this problem? How do i recover the files from the mirco SD card. Please guide
Click on the drive and then in windows select tools then folder options, then view and select or unselect hidden files or folders, plus hide protected files.
This should show all files on the card.
The only other thing I can think of is that the camera uses a different format to Windows. So it can't read the card.
SOURCE: transcend 1 GB removeable Pen drive is not detected
The pen driver is ifected with virus.Just format it with CMD and ur problem will be solved
SOURCE: usb flash drive corrupted
HI-
Have you tried reformatting it? please be advised that you will lose your file if you reformat it. but that could help resolve your issue.
Hope this helps.
SOURCE: pen drive display free space 0 byte and used space also 0 byte
Try formatting the drive. Assuming Windows XP, just open your "my computer" icon, right-click on the device and choose format. Be aware, formatting will remove any data you may have had on there previously.
If you're using another OS, or if it's an existing drive, please re-state your question giving further details (what OS, what you are trying to retrieve, etc).
SOURCE: U-MAX 2Gb pen drive showing free space 0 byte and used space0byte
Dear sir,
Here is the solution conect it to the system,right click on your thumb drive icon appered in your computer,go to the properties,then click on tools tab,then click on check now, if there is no check disk window,keep your pen drive to the system(dont remove) restart the system.now windows checking disk for error dont skip checking,it checks your thumb drive also,and fixes file system errors.after arrival of desktop now open my computer open your pen drive.Your pen drive must open normally. thi deffinately solves your problem.
If it not opening you have to format your pen drive no other solution for this.
if you have any problem regarding this issue leave a feedback,we will glad to assist you,
Have a nice day
good luck
