Frigidaire GLEB27S7A Electric Single Oven Logo
Posted on Dec 17, 2008
Frigidaire Wall Oven does not open once hot
I have a Frigidaire wall oven, oven adn broiler combo. The oven does not open after the oven is hot and food in in there...
  • mtarnoff1 Dec 29, 2008
    Frigidaire electric wall oven door will not unlock after the self cleaning mode, it is sending an F9 error code. I have reset the oven time - pressed clr etc and still remains locked - any suggestions besides blowing it up!!
  • Anonymous Jan 08, 2009
    Freaky, mine is doing the same thing after the self cleaning cycle, wish the others would let us know how they resolved the problem'
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
108
Points
Well at least I seem to have solved it. I kept hitting clear off and tugged on the door and it finally opened. Once opened I noticed there is a metal hook at the top of the opening to the oven. Mine was rotated to the 9 o'clock position. I took a pair of pliers and rotated it until the open part of the hook was in the 12 o'clock position and tugged outward on it just a bit and the "door locked" signal went off. I hit clear off again and the beeping has not resumed. I'm thinking the hook got partially stuck in the wrong position after it automatically locked the door for cleaning.
Waiting for the oven to completely cool off before I close the door again.
Hope this helps someone else out there!
While baking in frigidaire wall oven the broiler will sometimes turn on and code f3 pops up model FEB786CEBH.
The oven temperature sensor may be failing or defective. First, check sensor harness and harness connection between oven sensor and oven control to see if there is an issue with loose wires or visible damage to the wiring, such as a burnt wire.
Boiler does not work ellameny is good
Good Morning James, thanks for your post!
From my understanding your broiler feature is not working on your Frigidaire wall oven and the element is good. It could be a potential issue with the thermostat or connector of wall oven. If there is a miscommunication within the wall oven you may be able to perform a reset to clear the issues. If you would like to attempt a reset you would need to flip the household circuit breaker off for roughly ten minutes. If that does not correct your issue I would recommend contacting a professional technician for assistance in diagnosing your wall oven. Hope this is helpful. -Matt
How to get manual for the Frigidaire electric wall oven 27 inches?
You have several questions on here with diferent models, i suggest you go to the frigidaire website under owner support and register your model for a manual download. http://www.frigidaire.com/Owner-Center/Product-Support-Manuals/undefined
NEED BAKE ELEMENT FOR THIS MODEL
Hey friend, thanks for your post!
I understand that you are in need of a bake element for your Frigidaire wall oven, RGB94K. I would recommend performing an online search for antique appliances to see if any additional parts are available for purchase. I hope this information has been helpful. -Matt
Frigidaire double convection wall ovens, model GLEB30T9DSA ... The top oven will not heat, both the bottom element and the broiler.....
I have the Frigidaire PLEB30S8CCA single wall oven. About 3 months ago the baking element appeared to have gone out. We replaced it, but still didn't work. We ended up sending our control board off to a company named Corecentric. They fixed the problem and returned it to us. The oven has worked perfectly ever since. I searched extensively for a new one, but no one sold them anymore. I found Corecentric on Ebay. They were able to confirm over the phone that it was more than likely a control board issue. It cost about $130. My husband was able to do it himself by taking a couple before px and using them when reassembling it.
Oven won't get hot
If your oven still uses a pilot light, it also probably has a thermocouple positioned in the pilot's flame path to detect whether if is safe to turn on the main burner. When the thermocouple fails, the oven thinks the pilot light is not lit and will not let gas flow to the primary burners. The part isn't costly (should be <$20 US) but replacing it may require some expensive labor.
1helpful
Our Frigidaire 24 in wall oven won't light. The igniter glows but there appears to not be any gas present.
The ignitor is weak and needs to be replaced. You can not tell by looking at it. You have to measure the amp draw through the ignitor.
2helpful
Oven not heating
If the element only works partially or not getting red hot at the "Hi" setting, the problem might be with a burned out receptacle that the element plugs into. If this is the case, replace both the element and the receptacle.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
I have Fridgidaire 30'' wall oven. Tried to bake something but only the broiler will ignite. NOT the oven! AHHHH...I want to cook my meatloaf. Help?
your model says its a 24"
but the hot surface igniter for oven is bad
it should have a seperate one for broiler
check here on fix ya ( hot surface igniter)
Brand new Frigidaire FGB24S5A Gas wall oven not registering corre
some units will need to be adjusted if you live in a high altitude above 3000ft.
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
