Texas Instruments TI-30XA Calculator Logo
Posted on Dec 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mixed numbers i know how to do a fraction but not a mixed number. how do i put in the whole number of the mixed number?
Anonymous
Level 2:
  • Expert 43 Answers
  • Posted on Dec 31, 2008
Anonymous
Expert
Level 2:
Answers
43
Questions
0
Helped
43398
Points
102
Proper fraction e.g. 3/5, input 3, divide, 5, =, answer 0.6
Improper fraction, either enter as improper fraction, or enter the whole number first, then +, then the proper fraction as before, then =.
E.g. 8/5 which is "1 and 3/5': enter 1, +, 3, "divide", 5 =, answer is 1.6
Or, just 8, "divide", 5, same 1.6 answer. Why go to mixed number first?
13/5 which is "2 and 3/5", enter 2, +, 3, "divide", 5, =, answer is 2.6. Or, just 13/5, same answer
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
774
Points
P8 dn ƃuıɥʇʎɹǝʌǝ ppɐ puɐ ɹoʇɐuıɯouǝp uoɯɯoɔ ʇsɐǝl pɔl ǝɥʇ puıɟ sı op oʇ ǝʌɐɥ noʎ llɐ
2answers
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 • Homework
Reduce this tothe lowest terms 711over 22
The fraction 711/22 is an improper fraction (the numerator is greater than the denominator).
While there is nothing incorrect about this, an improper fraction is typically simplified further into a mixed number.
The whole number part of the mixed number is found by dividing the 711 by the 22. In this case we get 32.
The fractional part of the mixed number is found by using the remainder of the division, which in this case is 7 (711 divided by 22 is 32 remainder 7).
The final answer is: 32 7/22
What is mixed number in math
A mixed number is a number with a whole part and a fraction part.
1/5 of 16 is 3 1/5. The whole part is 3 and the fraction part is 1/5.
1helpful
A mixed number is a number with a whole part and a fractional part.
4.75 as a mixed number is 4 3/4. The 4 is the whole part and 3/4 is the fractional part.
Mixed numbers
If the result is positive, type in the integer part then add the fraction part either with the help of the fraction key or the division key. (I do not think that the TI82 has a fraction key.
If it is anything like the TI3 there is command under MATH >Frac. It should be pressed after you enter the mixed number to keep the result as a fraction.
If the mixed number is negative you enclose the whole number in parentheses. Press the change sign (-) key to negate the result.
1helpful
How do you enter mixed numbers ( whole numbers and fractions i.e 3 3/4)?
You cannot, you must enter 3.75. If you can't figure out what the fraction is, you must first compute the fraction (3/4=.75) and then add it to the whole number (3+.75=3.75)
Enter a whole number with a fraction
Enter the whole number ,then hit ab/c on your calculator enter the upper number of the fraction then hit again ab/c then enter the lower number of the fraction.That way yuo can enter a mixed fraction.Hope this helps.
I just bought a texas instruments TI-30X IIS Calculator. How do I reduced improper fractions with no mixed numbers. What keys do I press. For example: 3 6/8 X 7 1/3 = ? How do I find the answer?
if you want to use your calc for this you would have to put it in as the operations to change the mixed to improper fraction i.e. input exactly as "((8*3)+6)*((3*7)+1)="  remember?  take denominator times whole number plus numerator and put over denominator to convert from mixed to improper... hope this helps
1helpful
3answers
Mixed fractions
When you get a fraction for he answer: shift-S<->D[a b/c<->d/c]
This way, you change it to a mixed fraction or improper fraction
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
