While trying to set up a new remote, the tv went into lock mode and I can't get it out. Have tried unplugging it for a few hours and that didn't help. Don't have original remote. Model # 27E401
SOURCE: My channels don't come in
Boxes can be a pain. Do you have a Video or Av button on the box that you can try and press.
Sounds like TV is set up Ok otherwise the guide image would not go on the screen. My mother in Laws digital box often gives me curry. (first thing to advise - never buy mother in law technology - the old bag will call your cell phone at all hours to figure out why it isnt working - second words of advise - never give mother in law cell phone number)
First thing to do simply unplug the bloody thing from the power socket to reset it.
Failing this It is often the video mode outputs on the box that are not set up properly. Even though the startup image and guide comes on unless the correct video image output is set up properly you will not be able to view the TV.
SOURCE: Our tv screen went completely
hI AS YOU DID NOT GIVE A MAKE OR MODEL I CAN NOT GIVE A PRECISE ANSWER BUT IT SOUNDS LIKE YOU HAVE NO BACK LIGHT. THIS IS USUALLT DUE TO A FAILURE OF THE INVERTOR ASSY OR AT WORSE THE BACK LIGHT IN THE SCREEN.
YOU NEED A SERVICE ENGINEER TO CONFIRM
SOURCE: My remote won't set to
Hello
You might have a cellphone with camera option. Set the cellphone co cemera mode, and place the remote control at about 1 feet away from its camera lens, and press each button on your remote control. Remote control emits infrared rys as we press each button, but can't be detected by human eye. Electronic cameras can detect it. If there is any infrared ray emission from your remote control you will see its image on the camera screen for each button press to your remote control. If there is image and still the Tv doesn't respond to it, The TVs' infrared snsor inside has damaged and should be replaced. If there isn't any image; check the battery contacts of the remote battery compartment first. Clean these contacts by using a piece of corborandum paper or with the tip of a razor blade. Improper battery contacts, due to rust and dust to these contacts will prevent the battery supply voltage to enter into the remote contro.
Still it doesn't work at all, the remote control is damged and should be replaced. Contact the nearest Vizio Authorised Service Cente fro original remote control. OK.
SOURCE: Set-up mode?
Some of these TVs were assembled by AKAI.I would suggest you program the remote for AKAI. You may be able to get more options from the remote. Thanks for asking me.
SOURCE: TV picture won't come on, just get white static
Hello
There may have some crack or loose to the circuit board during drop. Just get it serviced. No more component should be repalced. Only service should be done. OK.
1.
Hold down MENU
on the remote and VOLUME DOWN on the TV it's self at the same time for at least
4 seconds. The set won't say so, but the lock will be unlocked
2.
Hold down the 0
on the remote and the VOLUME DOWN buttons on the TV its self at the same time
for at least 4 seconds. The set won't say so, but the lock will be unlocked
3.
Hold down the
MENU button on the front of the TV and the TV button on the remote at the same
time for at least 4 seconds.
4.
Hold down GO
BACK on the remote and MENU on the front of the TV at the same time for at
least 4 seconds.
5.
Hold down EJECT
on the front of the TV and the MENU button on the remote at the same time for
at least 4 seconds.
Depending on the
model, one of the methods should unlock the V-chip. Now, if desired, you can change
the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS,
or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Any one amoung the above process will unlock your GE TV. After unlock, you have to do the Vchip-Set.
