Question about JVC Everio GZ-HD7 Camcorder
Maximum capacity sd card for gz hd7u ?hey what is the maximum sd card i can use for the jvc hd7u ? the book says class6 4gb but i was told diffrent ! can someonew confirm?
SOURCE:
  • 148 Answers
SOURCE: which sd card to buy
I would recommend a 2GB card. That will give you maximum storage. There are bigger SDHC cards, but the compatibility is somewhat reduced.  Buy from any reputable store. Avoid prices that are extremely low, these are likely to be counterfeit cards.
Posted on Dec 12, 2008
Ciza24
  • 59 Answers
SOURCE: UpDated Firmware for the JVC GZ-HD7U.
There currently are no updates for the camcorder, they discontinued the camcorder shortly after it hit stores.. seemed to have alot of issues.
To the other user with the similar issues. The camcorder isn't the same as a DV camcorder and you may not be able to capture live. My suggestion would be to mount the camera using the USB cable and copying the video files from the camcorders internal hard drive to your desired location.
You may need an application to convert the videos, I suggest MpegStream Clip. They have a version for PC and Mac.
Posted on May 07, 2009
SOURCE: Manual for JVC GZ-HD7U
i recorded my video clip vertically! i need to rotate them from the camcorder! how do i do it????
Posted on Sep 22, 2009
SOURCE: JVC CAMCORDER GZ-HD7U
HI, I FOUND A METHOD TO WORK WITH TOD FILES,FROM EVERIO, BUT IS NECESARY,COREL VIDEO STUDIO 12 TO FIX THIS PROBLEM, ANY TOD FILE YOU WANT PREVIOUSLY RECORDED YO HAVE TO PUT IN TO THE TIMELINE TO EDIT AND LOOCK FOR OPTIONS" SHARE" ( FINAL RENDERING)FOLLOW THIS STEPS: FIRST: VIDEO ON TIMELINE TO EDIT, 2. PRESS SHARE LOOCK FOR CREATE VIDEO, IS GOING TO APPAER A WINDOW WITH NEW OPTIONS, 3 LOOKS FOR MPEG OPTIMIZER NEXT THE FILE IS GOING TO RENDER IN FORMAT MPEG , 4 ASSIGN THIS FILE ON YOUR PC WHETEAVER YOU WANT TO BE SAVEDT.HIS TAKE ALMOST SECONDS ( JUST TO CONVERT WITH OUT ANY ARRANGEMENT TO YOUR VIDEO, I RECOMEND TO CONVERT THIS FILE AND YOU HAVE A NEW MPEG EXTENSION FILE WITH VERY GOOD PROPERTIES TO WORK WITH ANY SOFTWARE YOU DECIDE NEXT, IS BETTER THAN POWER DIRECTOR BECAUSE WITH POWER DIRECTOR I NOTICED A LOSSS IN QUALITY, ALSO THERE ARE FRAMES FREZEED IF SOMEBODY SEE MY POST I WUOLD LIKE TO HAVE A CONFIRMATION ABOUT THIS PROCCES THERE AREN'T ANY LOSS IN VIDEO QUALITY , FOR ME LOOKS VERY GOOD BUT I LET THIS TO PEOPPLE MORE EXPERIENCED TRAY AN CONFIRM MY METHOD
THANK YOU
ALEVI
Posted on Nov 08, 2009
sure_thing
  • 157 Answers
SOURCE: jvc everio GZ-MC500 does not recognize High
Beyond 2GB SD Card this model can not support. Why? because this model carries the logo SD, where as 2gb is the maximum, although there are some companies manufacturing SD with the capacity of more 2 GB but this is illegal(not standard for SD) do not conform with SD. New models can support HCSD (High Capacity SD) as far as 32GB can be found in the market. Hope this helps
Posted on Mar 05, 2010
What is the maximum SD capacity that jvc everio gz mg57 can support?
You may use any size SD card. Bear in mind that SD cards only go up to 2GB. This camera will not work with higher-capacity SDHC cards.
Dec 29, 2013 | JVC Everio GZ-MG57 1.3MP 15x 30GB HDD/ SD...
I have JVC GZ-MG20EK and when I insert the SD card, it keeps saying I dont have a memory card in there?
Make sure you have an SD card, 2GB or smaller. This camera will not work with higher-capacity SDHC cards.
Dec 22, 2013 | JVC Everio GZ-MG20 Camcorder
What does it mean when I get a message that says "please insert memory card" on my JVC Everio GZ-MG21U?
Make sure you're using an SD card, not a higher-capacity SDHC card. The GZ-MG21U works with SD cards, not with SDHC cards.
Sep 24, 2012 | JVC Everio GZ-MG21 Camcorder
Hi I inserted a new 8GB sd and the camera keeps trying to re-format. GZ-MC 200
There are no 8GB SD cards. A card that size is actually an SDHC card. SD and SDHC cards fit the same slots, but they are slightly different. Many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Unless your manual specifically says that your camera can use an SDHC card, then it won't be able to. The maximum size of an SD card is 2GB. If you need more space, just carry a couple of cards and swap them, like people used to do when they filled up a film.
Dec 25, 2010 | JVC Everio GZ-MC200 Camcorder
I have the JVC above and it requires an SD card. I inserted an SDHC card and it gave me an error. SD and SDHC are not the same? When I did try to but SD card only still on its label has SDHC. To be honest...
You are correct. SD and SDHC are not the same.
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
SDHC stands for Secure Digital High Capacity. It was a technical evolution which broke the 4GB maximum capacity of SD cards and allows up to 32GB. In turn they are eventually due to be superseded by SDXC cards (ecure Digital eXtended Capacity) which allow a maximum of 2TB.
May 30, 2010 | JVC Everio GZ-MG37 Camcorder
No disc for my JVC Everio GZ-HD7U
You don't need the disc. Buy Corel's latest videostudio x2 for editing. To extract the video files from camera just plug into computer with USB cable and search the camera for files.
Jan 01, 2010 | JVC Everio GZ-HD7 Camcorder
Jvc everio GZ-MC500 does not recognize High capacity SD
Jul 14, 2009 | JVC GZ-MC500 Memory Card Camcorder
Which sd card to buy
Dec 12, 2008 | JVC Everio GZ-MG21 Camcorder
Sd card capacity on JVC GZ-mg37AA
you can buy up to an 8 gb sd card i saw them in walmart and radio shack
Aug 11, 2008 | JVC Everio G Camcorder
I have a JVC Everio GZ-MG21EK Camcorder can anyone tell me the maximum sd card that you can use with this camcorder
There is no limit beyond the limits of the SD cards themselves. The JVC Everio GZ-MG21EK camera DOES NOT support SDHC cards, so you are restricted to the smaller capacities of the non-SDHC SD cards. I am successfully using a 2GB SD card in this model.
Stewart
Aug 03, 2008 | JVC Cameras
JVC Everio GZ-HD7 Camcorder Logo
118 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Thomas F. Schneider
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
