SOURCE: samsung digimax 130 camera memory error
If memory card is full, just try to delete one picture and try to take a picture and check if it will be saved in the memory card.
There is a Delete All option.
Or if you want to, you may format the memory card and the pictures will be deleted.
SOURCE: troubleshooting
Possibly overloaded.
The phone needs some memory to operate.
When you take a pic you can choose where to store it.
If you store a pic on your phone memory and them move it to a folder, and you later on decide to delete the pic from the phone memory it also deletes from the folder.
SOURCE: Memory full; how to clear
Sounds like you will need to format the internal memory of the camera. This will permanently erase all the data from the internal memory and then you will be able to use it again. To format the memory: Remove the xD card from the camera - Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the memory so it can be used again.
SOURCE: Panasonic Lumix DCM FS5 camera. Inbuilt Memory
delete the pictures (you should be able to upload them first)
