We just went through this with our 2003 Rendevous. Clicking like crazy but wouldn't start. Replaced the starter but still doing the same thing. Our next step was going to be replace the battery (which tested well) and the ignition assembly. Out of frustration, I hit the top of the hood and the headlights came on!! Further investigaton proved that the problem was a corroded ground wire on the battery. Hope this helps
SOURCE: 2002 buick rendezvous
My gas guage went from Empty to Full on its own and I never knew how much gas was in my vehicle. I was driving the other day and it stalled. Pulled into a parking lot let it sit a bit and it started right back up and I was able to drive again. Went to nearest gas station to put gas in. I put in $10 and I drove 3.4 miles and well it died on me again. I pushed the vehicle into my garage. I called around to see what could be wrong and I was told numerous things. I finally went under the vehicle where there is this clearish/white box under the Driverside area and I noticed it was corroded and dirty. I went in the house got a spray bottle with HOT WATER and sprayed it. I noticed that I had 3 prongs broke off. So I went to a local dealership for GM/Buick and I got the pins I needed to fix the problem and I went home fixed the broken pins and well now my vehicle works great and the vehicle runs great and gas guage problem was fixed as well. So for all of you that think you might have a fuel problem, fuel pump problem or gas guage problem check into the wire harness box under your vehicle and you will be able to fix it for Pennies instead of paying the $750 or more for something you cna fix at home. I love my Rendezvous and I would buy another one again.
SOURCE: How to Change an Ignition
Please let me know if you have questions, and thanks for using FixYa.
Fig. Lift the trim cover in order to gain access to the lock cylinder access hole.
Fig. Remove the ignition lock cylinder from the lock cylinder case.
Fig. Driver-s side air bag connector location
Fig. Passenger-s side air bag connector location
Fig. Side air bag connector location
Removal & Installation
To install:
NOTE
Use the correct fastener in the correct location. Replacement
fasteners must be the correct part number for that application.
Fasteners requiring replacement or fasteners requiring the use of thread
locking compound or sealant are identified in the service procedure. Do
not use paints, lubricants, or corrosion inhibitors on fasteners or
fastener joint surfaces unless specified. These coatings affect fastener
torque and joint clamping force and may damage the fastener. Use the
correct tightening sequence and specifications when installing fasteners
in order to avoid damage to parts and systems.
Disarming the SIR System
NOTE
With the fuse removed, the AIR BAG or SIR light will illuminate if the ignition switch is turned
ON
at any time. This is normal and does not indicate a problem when the system is disarmed.
Arming The SIR System
SOURCE: 91 Buick Roadmaster wont start....... Baffeling
If the engine will not turn over using the starter then it cannot be the fuel pump. If the car has a factory inhibitor system installed, the chances are that it is this system that is preventing the car from starting. You may not have to press a button on the key fob either, it may have a transponder built into the key fob which transmits it's data at switch on.If you don't have the correct key or a key without a keyfob then the anti-theft system will NOT be disabled and the car will not start. There is no easy answer for this as you need the correct keyfob or you need to purchase and have programmed, the new keys.. If this is not the issue, let me know and I will describe further procedures for your issues..
SOURCE: buick rendezvous will not start with key in
check the starter relay..check neutral sw..both may be unplugged or defective ...good luck
