The RH397H will play AVI files well, but not MP4. Is there a software update?
The LG RH397D only supports MP3/WMA/JPEG/DivX image and audio files from a USB drive. There is no firmware update that changes the supported file types. You will need to convert the MP4 to a supported format. The manual for the RH397D is available from LG: http://www.lg.com/au/support-product/lg-RH397D# /
I wish that I had better news for you.
SOURCE: what kind of DivX files
PLAYABLE CODEC FORMAT
files DIVX3xx - DIVX4xx - DIVX5xx - XVID - MP43 - 31VX
PLAYABLE DivX file -.avi,.mpg,.mpeg
SOURCE: lg rh397d and the hello lcd just keeps playing but
Problem is caused by unstable 12v supply to HDD.
To fix you need to replace the 1000uF 25V capacitor in the power board. The failing capacitor has a expanded casing and there was two of these in my daughters unit.
Worked OK once I replaced the 2200uF and the 1000uF capicitors.
GDW
SOURCE: I can't play MPEG-4
Refer to its user manuals' specification sheet. You can see all details about the formats that this player can read.
SOURCE: i have a fat32 usb stick with but the bd370 could not play the movie
resave the file to your computer, and reformat using NTFS. retransfer to the stick, and it should work after that.
