Question about M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card
I have a g5 mac running pro logic 7 I have a delta pci card. All analog input work but i cannot find the digital inputs or get them to work in logic pro 7 on a mac
I have used mac for many years and never had this problem . Previous sound card was audiowerks on a g4 . I have the upto date drivers for the delta card but cannot configure or get digital in to work or even find it in input select. I am trying to record from dat d/o
2 Suggested Answers
SOURCE:
  • 1027 Answers
SOURCE: Nasty ***** distortion on Delta 1010's on Mac G4
Your first line stated the obvious; the PC can run 2 cards, but the G4 cannot. The Mac, although a 'PC' has significant hardware differences with an IBM derrved PC.
Posted on Feb 02, 2010
I want download a sound card fw8280 1db intel .where i can do it?
you cant download a sound card but you can download sound card drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
http://www.boxdrivers.com
using this link you will be able select your drivers
http://download.cnet.com/m-audio-delta-drivers/3000-2120_4-14794.html
http://download.cnet.com/delta-series-digital-audio/3000-2120_4-34788.html
if these arent right you will find free sound drivers
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for ie:intel laptop
(be precise)but don't use numbers or / - also the download software finder under that there will be a list place a tick in the box of any one you want/need
all software windows software mac software mobile and web apps
http://majorgeeks.com/downloads35.html
Sep 01, 2011 | M-Audio Audiophile 192 Sound Card
Date and time changes if left for short time
Only date & time are changed? Are they reset to year of 19XX?
If it is, that problem usually is caused by low Bios battery.
You should replace it.
May 19, 2011 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
I have a G4 PowerMac Sawtooth which was given to me, it has an OWC 1 GHZ. PowerPC CPU processor board with the gold colored heatsink and single fan. It has 1GB of PC-133 RAM and the latest firmware...
It is possible you have a power supply failure. My MDD was doing the same thing unless I reset the PMU. There is a tutorial here on checking the PS - D275729F-09DA-4FBB-96B3-BEEEB2C04619.html It for a MDD, but I would think it would be useful for your situation.
Do you have an Intuos tablet connected? The drivers for that might be causing the problem and should be updated to the newest driver available
Oct 10, 2010 | Apple Power Mac G4 Desktop
Feb 01, 2010 | M-Audio Delta 1010LT Sound Sound Card
PowerBook G4 does not seem to recognize. (Worked well on previous Apple lap top)
If your Firelite SmartDisk was formatted for a PC, and you are using the Mac side of the G4 it won't. They use a different format scheme. Need to load Parallel, bootcamp, or another virtual PC program, and then Windows. Using that it will recognize it.
If you know another Mac user that is using both sides (Mac and Virtual PC) is a quick way to retrieve data to move it. Be careful reformatting the FireLite. There are some more complex ways. Hope that this helps.
AAirwolf
PS: I use a 160GB FireLite on my G4, MacBook Pro as well as my Tower and notebook PCs.
May 24, 2009 | FireLite (USBFLB80) Hard Drive
For my mac g4 first generation, i bought a Ati radeon 7000 PCI. the goal was to stop using my original graphics card and use the ATI radeon 7000 for my main and only screen but when i start up with my...
hello...the way is try to open the Bios Settings then disable the on board video then set primary AGP/PCIE slot Video Card to run then try again to install the video card driver but 1st you need uninstall the old driver..thanks and Good Luck..have a nice day..^_^
May 12, 2009 | IXMicro ix3D Dual Monitor (8 MB) Graphic...
USB reads wireless modem, software doesn't!
mac doesn't support any data card till date so this is not working . if you want to connect it install windows using bootcamp then your problem will be solved. if something importent rate this article
May 09, 2009 | Apple iBook G4 Mac Notebook
AirPort Password
This article provides instruction on the installation of the AirPort Wireless Networking card into a Power Mac G4 (AGP Graphics) computer. Similar instructions, with graphics, are included with the AirPort card.
1. Shut down the computer (choose Shut Down from the Special menu) and unplug all cables except the power cord.
2. Touch the metal PCI access cover on the back of the computer to discharge static electricity. Avoid walking around until you have finished installing the card. Unplug the power cord then lift the latch on the side of the computer.
3. Gently lower the side panel onto a clean, flat surface. Lower it onto a soft cloth to avoid scratching the case.
4. Connect the antenna cable to the connector on the end of the AirPort card. The cable is usually stowed on the side of the PCI card guide.
5. Remove the metal clip and pull the AirPort card from the adapter card, shown below. The adapter card and clip are not used with your Power Mac G4.
6. Insert the AirPort card (serial number side up) through the opening in the PCI card guide, and into the connector on the main logic board as shown below.
7. Raise the side panel and press it against the case until it snaps into place.
Instructions for using the AirPort software are in Mac Help, available in the Help menu.
Wireless Internet access requires an Internet service provider (fees may apply) and AirPort (or AirPort-compatible) wireless Ethernet card and base station. Some ISPs are not compatible with AirPort. For more information, see technical document 106590: "AirPort: Requirements for Wireless Internet Access"
try the above link to get more detail.
Thank You
Sep 11, 2008 | Apple (APP M7600LL/D) Wireless Adapter
Apple g4 aluminium
What sound card are you using? It has to be external for you to switch it. When a computer is dropped, the hard drive and logicboard are under severe danger. The drive is constantly spinning anywhere between 4200 and 10k rpms. If the logicboard endures any shock there could be endless possibilities to failures in addition to them being intermitten. Can you specify which G4 you have, in processor speed and machine/display size? And I take it when you mean " no sound", you also mean no Apple start-up chime when you boot the machine?
Oct 02, 2007 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Soundcard problems
I'd say to look at latency settings and sample rates. also disable screen savers and power management.
Jul 09, 2007 | M-Audio Delta 66 Sound Card
M-Audio Delta 1010 PCI CARD Sound Editing & Recording Sound Card Logo
35 people viewed this question
Top M-Audio Computers & Internet Experts
Thomas F. Schneider
John Bolton
bigdaddyd2
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
