May i have the code for a sharp tv using kevin rm 88E universal remote?
These are the codes for Sharp TV; 0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122 Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. Setup proceedings are described there in detail. Check this link too.
SOURCE: i need codes for panasonic tv, using the chunghop rm-88e
Try 01, 02, 03, 04 or 45. Good luck!
SOURCE: code for universal remote rm-810
There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
2. Point the RC right to the "Device" .
3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
You can try the RC now. It should work. My one is working.
SOURCE: i digital universal remote RM-810 - need code for
Try 184 for the NEC TV.
Please rate this solution. Thanks.
code for sanyo kevin universal
