I lost my password for my only account on my dell laptop and it wont let me in to change it. I need help getting the adminstrator password off.
Recover Dell windows password, you can do as below:
Google Search "Windows Password Recovery Tool 3.0"
One of my friends recommended me to download Windows password recovery tool
to erase Windows system password, and this Windows password recovery tool was really good.
It removed my windows admin password without data loss.
Related: http://www.windowspasswordsrecovery.com
SOURCE: Administrator password problem
you will have to contact Dell technical support, they can generate a master password for your system.
1-800-624-9896
or chat with them
http://support.dell.com/support/topics/global.aspx/support/chat/hardware_chat?c=us&l=en&s=gen
SOURCE: the administrative password is different in the bios settings
You can reset the password easily by removing the battery which will clear the CMOS. If you aren't comfortable doing this, perhaps you can find someone who will do it for you. It's not hard to do, and you won't hurt anything as long as you unplug the computer and discharge any static from your body. (Just touch something metal - like the rails on your desk or something else.)
SOURCE: Dell XPS M1210 Administrator password and password log on problem
This is a known vista issue where it creates a backup of your profile for some reason there registry edits to try and fix it but a system restore is much easier. Follow the below steps to solve problem.
Turned computer on and immediately pressed F8 repeatedly until I got "Advanced Boot Options" select "Safe Mode" computer then opens safe mode login as admin if possible, with a "Help" window, in the help window there is an underlined "What is System Restore?" then select "Click to open System Restore" restore to a previous state before which the fault occurred.
Click OK and after config changes should be good to go.
SOURCE: dell latitude d620 bios password removal
To remove a BIOS password will require the assistance of Dell Tech Support. 800-624-9896 You will have to be able to prove you are an authorized user and if out of warranty a Fee may be involved.
SOURCE: dell inspiron 5150 laptop, reset admin. password.
Restart your laptop and keep tapping F8 key the moment you see something on the screen. You will get a black screen with some options written in white. Select the option Safe mode and then you can create a new user with admin rights. Or else at the windows login screen press and hold ctrl and alt key and tap delete key twice and then it will take you to a login screen. Dont put any password there just hit enter. And you will be able to login with admin rights.
Thanks
Deepak
