Please supply instruction manuals (in English) for the following Neff models:
Neff double oven U1524
Neff gas hob T2986
Please send a copy to my home address: 13 Brittons Ash, Bathpool, Taunton, Somerset TA2 8BS.
Alternatively send digital copy to my email: [email protected]
Thank you Kevin Sydenham
SOURCE: Instruction Manual Needed?
Hold cook time button and stop time button together and while both buttons pressed in, use + and - buttons to set time.
regards Paul.
SOURCE: NEFF HOB
Your heater is probably equipped with a bimetal thermal switch to prevent overheating and, if it is like most made in China now, it is defective or at least highly inaccurate.
If you can locate the device, using a metal shield to divert some of the heat will help it serve its original function as a safety.
Look for a thick (4-5 mm), button-like device with two terminals and a diameter of 1.5-2.0 cm.
This point of failure is shared with a majority of drip coffee makers that fail way too early.
SOURCE: diplomat 910-need instruction/fitting manual
Eventually I have tracked down the manual on ebay-it is available through the seller ' usbdesarch' who appeared to have a selection of manauls available. If I can post a copy on here when I recieve it I will though I'm not sure how to upload a PDF? Any ideas how I would make this available to the widest audience? I have no website to host the file from.
SOURCE: I need an instruction manual for a stoves heritage 720EF oven
Access details via email on its way to you shortly.
