SOURCE: Craftsman Chipper-Shredder Model No. 247.775870
If a small engine wont start its usually one of two problems, its not getting gas, or its not getting spark. easy way to find out if its getting a spark is to remove the plug, put it back back in the connector and just let it hang down while you try to start it. you should see a bright blue spark, if you dont try changing the spark plug. if its getting a spark come back on this site and i'll help you trouble shoot it.
SOURCE: 9hhp craftsman chipper shredder won't start
Squirt a couple of spoonfuls of oil into the spark plug hole to increase the compression as it has been sitting so long. Also squirt a little starting fluid into the carb. and give it a shot I think it will start. Hope this will. donnyb60
SOURCE: how to change oil to craftsman chipper 24779594
You can download a PDF manual for your chipper at ( www3.sears.com ) Type your model number like this ( 247.795940 ) It will show you a parts list for it and also there will be a place that says "Manuals" click on that and it will download to your computer where you can eithewr save it or print it out or both
SOURCE: I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
SOURCE: craftsman 8.5hp chipper/shredder model 247.775880
here... here's a pdf manual for u
and they also discuss play by play changing the oil for u.
good luck... post if u need more answers....PK
