HP LaserJet 3050 All-In-One Printer Logo
Posted on Dec 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i download users' manual. I need to get the automatic "9" out of the outgoing fax number.
Anonymous
Level 2:
Sniper:
  • Expert 87 Answers
  • Posted on Dec 22, 2008
Anonymous
Expert
Level 2:
Sniper:
Answers
87
Questions
Helped
174188
Points
206
Inserting a dial prefix A dial prefix is a number or group of numbers that are automatically added to the beginning of every fax number you enter at the control panel or from the software. The maximum number of characters for a dial prefix is 50.
The default setting is Off . You might want to turn this setting on and enter a prefix if, for example, you have to dial a number such as 9 to get a telephone line outside of your company telephone system. While this setting is activated, you can dial a fax number without the dial prefix by using manual dial. For instructions, see Using manual dial .
To set the dial prefix
  1. On the all-in-one control panel, press Menu .
  2. Use the < or the > button to select Fax setup , and then press how can i download users' - c00597634.gif .
  3. Press the > button once to select Fax Send setup , and then press c00597634.gif .
  4. Use the < or the > button to select Dial Prefix , and thow can i download users' - c00597634.gifg src="/uploads/images/c00597634.gif" alt="c00597634.gif" class="h_mi" /> .
  5. Use the < or the > button to select Onhow can i download users' - c00597634.gif , and then press c00597634.gif .
  6. If you selected On ,how can i download users' - c00597634.gifanumeric buttons to enter the prefix, and then press c00597634.gif . You can use numbers, pauses, and dialing symbols.
To get the manuals visit the following link:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodTypeId=18972&prodSeriesId=1140783
Regards,
Nikhil Gedam
Can you add a new fax no that shows in the header for outgoing fax?
To set Outgoing Fax Number/ ID follow the follwing steps: -
- Press FUNCTION, Press 7 (Set mode will appear on display)
- Press 1 (User Parameters Settings)
- Press Set repeatedly until display shows ID
- Enter your Number/ ID (max. 20 digits) by using the key pad
For further information you may refer to User Manual for Panasonic Panafax UF-585 Page 29
Hope it helps! Good Luck!
CreativeTECH
1helpful
I would like to block all incoming faxes on the faxcentre f110 so that it is an outgoing fax only, how do i do this?
You don't really need to block incoming faxes, but just set the machine not to automatically answer them. This figure is from the manual:
Press the MODE button until you see MANUAL displayed. In manual mode you need to answer and start receiving a fax yourself from the machine.
You can download a copy of the user manual from Xerox if you need it.
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
3helpful
Need to change the outgoing name and address on a Canon fax G3 L2
To change outgoing name and address, use the following procedure:
1 Press Function.
2 Press Data Registration.
3 Press OK twice
4 Use UP Down arrows to select Unit Telephone #
5 Press OK
6 Use the numeric buttons to enter your fax/telephone number (max. 20 digits,including spaces).
• To enter a space, press Function
then Space. Spaces are optional
but make the number easier to
read.
• To enter a plus sign (+) before the
number, press #.
• If you make a mistake, press C and
re-enter the number.
7Press OK twice.
8 Use the numeric buttons to enter your name or company name (max. 24 characters, including spaces).
9 Press OK.
10 Press Stop to return to standby mode.
Below is a link to your L=220 User Guide:
Canon L220 User Guide
I hope you find this answered your question. Best of luck to you!
Greg
5610 issue
dial 9 then pu in 4 to 6 ",,,,,," then the number.
old fashion fax method, don't knock it, it works
Removing fax prefix
it's in your settings..usually, it will say 9,,1 etc...just remove the 9 and commas..
this link might be of some help to you
k24674
Grand Canyon Tech
Grand Canyon Tech
