Food is freezing in my Frigidaire side by side and also the ice maker stopped working at around the same time.
SOURCE: my frigidaire refrigerator does not
Had this same problem. Ice formed on the back of the freezer compartment, but the refriderator area would be about 50 degrees. Checked the fan and defroster timer and everything worked fine. Watched it all defrost and ice build up again. Finally called for service. First guy said he needed to take the unit back to the shop. Second guy said there was an internal leak in the sealed case...couldn't be fixed. Finally realized I had bought an extended warranty (yippee!!) and called the authorized service dealer. Tech came out, said there was a service bulletin whereby the freon line by the evaporator coils was bent a little to extremly and was causing a restriction in the freon...thus the ice build up. He tweaked the line a little and now it has run perfect for 6 months. Would be nice if these bulletins from the factory were posted somewhere...
SOURCE: ice in the bottom of frigidaire side by side frost proof freezer
take all the bottom shelves and baskets out of the freezer. look at the back wall of the freezer. youll see a block of ice in a metal pan looking part at the bottom of the rear panel. there is a hole in the bottom of that pan. thats the defrost drain. its clogged. use a hair dryer to get all the ice out then use hot water to flush out the drain hole.
SOURCE: Frigidaire is freezing everything
yea the proper fix for the machine is a control assy part number is 5303918283 this is the complete kit.
sounds like that they just replaced one of the parts in the kit
this is the factory proper fix
SOURCE: My Frigidaire two door Refrigerator freezes food
door not closing (ajar) or cold control is bad or defrost problem
SOURCE: Frigidaire ice maker not working
The first step you need to do is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board. If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker. You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Thank you for contacting Fixya.com
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
