Hoover UH70400 - Windtunnel UH70400 Upright Vacuum Cleaner - 11 A - Bagless Logo
Anonymous Posted on Aug 05, 2012
Hoover windtunnel air - stopped working
Stopped working, Loud noise and air being blown through the port on the top of the canister underneath the handle.
Antonio DiFruscia
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Dec 28, 2012
Antonio DiFruscia
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1412
Points
5
I just has the same problem, there is a clog in the intake hose. I removed the hose and used a cloth dryer lint brush to push out the clog.
Overheated motor will not reset
It may take a while to cool and reset. If ity has been over an hour the thermal switch could be faulty.
Hoover WindTunnel WindTunnel vacuum cleaner Owner Manual Thermal Protector
The room smells after vacuuming, even after changing the bag. What can I do to stop the smell.
There may be a build up of dust in the machine. Turn it over and remove the screws that hold the beater bar cover and see if there is any white like powder caked on the inlet area.
My henry hoover wont work
check main cable & power switch, mAY BE FAULTY
3helpful
2answers
Why would hoover carpet cleaner make a loud noise, start smoking and now won't come on.
I'm afraid you burned a coil in the motor. And accidentally it stopped while that coil is between the contact brushes. Or one of the (or both) brushes are worn.
Hi i am also having problems with my Henry it started making noises from the motor then smoking and now every time I try to switch it on it trips the electric out. Could this be the carbon bushes need...
1st are you in America or Europe? 399$ here I did a bit of searching it took a while but these should give you some insight go to manuals click the Henry pict
1helpful
Emptied the hoover and now it wont switch on
The switch that is activated by the canister is your likely culprit based that it was working prior to emptying. Youtube has a quick video on this solution.
Uh70600
Take the filters out and turn the vacuum on, if it will stay running without the filters in it you need to replace the filters. Filters should be replaced every few months. Clogged filters still pick up some dirt but miss a lot plus it causes the motor to run hot which will cause damage to the motor reducing it's life.
1helpful
Electrolux lux legacy
open up the unit, locate the cord reel, manually retract it to tighten the clock spring. should work again. lookout for broken plastics
1helpful
How do i replace the release lever on a hoover windtunnel
This is definitely one of those "easy when you know how" things. No screws or plates or anything to remove. It is a case of getting the old one out and slipping in the new part:
The part clips in so you need to unclip the old (broken) one to get it out.
You need a small flat head screw driver to unclip the old one. You come into the opening via the UNDERSIDE of the vac as in pic one. You will release it and pull the old part out via the top side.
Below is a pic of the removed (broken) part. The arrows show the two round nipple like ends and these are what you need to release using the screw driving (and then pulling the part out the top).
Once you have the old part out the new one is slid in via the TOP of vacuum and clicks into place
This next pic gives you an idea of what you are trying to achieve.
The RED arrows are the new part in place. The YELLOW arrow shows what the "two round nipples" click into.
Sorry the pics are not better.
Tony Bowling
CAR DIE WHEN SLOW DOWN OR STOP AND LET GO THE GAS
i went to my mechcanic the same day my engine started to make the same loud noise that you are talking about. he said that it was the flex pipe. just this morning (5:30am 8/3/09) i went to dunkin donuts for my morning coffee and while waiting in line, my car just stopped running. like you said, when you take your foot off the gas and press the break, the car stops. no doubt about it, it is the flex pipe. im sure by now you got your car fixed but i thought that i'd share my car troubles with you :)
Top Hoover Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Hoover Air Purifier Expert? Answer questions, earn points and help others
