I connected the usb cords and click on the removable disk and it told me to insert disk into drive F and i'm lost like what disk?
Once you plug in the USB a small usb icon will apear in the top left of your gphone drag it down then tap it, voila (took me ages to figure this out)!
Hope this assists - someone asked the same type of question - here's the answer to getting the PC to recognize the G1 via USB -
I had the same issue, however what I DID notice up on top was a USB
Connected - the USB icon. I pulled that notification up and it asked me
to connect. The exacts are:
1. Plug the USB cable into the computer
2. Plug the USB cable into the phone
3.
The notification up top corner left will say "USB Connected" with a USB
notification icon - BRIEFLY. The text "USB Connected" will quickly
disappear, but the icon is still in the left corner.
4. Pull down
the notification andyou'll see "USB Connected - Select to copy files
to/from your computer" - Select that notification
5. Notification
"USB Connected - You have connected your phone to your computer via
USB. Select "Mount" if you want to copy files between your computer and
your phone's SD Card." - Select the option "Mount".
6. The "Removable Disk" notification should pop up asking you what you want to do. I select "Open folder to view files".
There is a music folder in there, or whatever else you'd like.
This happened to me, I too mounted the phone to the computer by dropping down the notifications at the top but it still didn't fix my problem, the problem was solved when I connected the phone to the 2.0 (high speed USB port) on the back of my computer, the regular usb port on the front of my computer did not support it.
This solution is absoultely perfect!!!!
Thanks a million!
NP
SOURCE: i can't seem to download music to my G1 t-mobile phone?
Did you Mount the G1 to your Comp? When yo plug in the USB the USB symbol should appear along the top of the screen drag down the menu and select mount USB
I GET THE SAME, IM GOING TO TRY A MICRO SD CARD ADAPTER AND PLUG TO LAPTOP THAT WAY
NOT SURE IF IT WILL WORK THOUGH.
IF YOU FIND A SOLUTION HOLLER WOULD U AND I WILL DO LIKEWISE LOL CHEERS
I cant load music to my G1
I have the same problem but even when i "mount" the usb to the computer, it still does not work
hey i followed Zyriana instructions but it goes wrong at step 6! when the pop up comes up it doesn't ask me what i want to do it just immediatly starts taking all my photos from my phone and putting them on the laptop!
so i can't get any music on my phone because of that and because i can't work my blutooth.....HELP ME!!
x
When i mount my G1 to my PC and try to move a file onto it, it tells me I/O Device Error.......PLEASE HELP
Ugh I get everything except step 6 that Zyriana posted. Nothing like that comes up and I tried it a billion times. I don't know what else to do.
same exact problem. ive tried everything and im pretty comuter savyy this is just not making sence to me
the USB thingy comes off when i press mount i dont even know what folder to pick
I can't download music to my g1
can/t put musice from my computer to my phone all it say put disk in what disk
My G1 Device does not have a USB icon at the top left corner of the homescreen but it says that it is charging with the notification of the orange light on and the battery icon charging does that mean i need a new USB cable?
