When i try to add friends it freezes for a minute. it doesnt add them. every time i sign back into messenger the same friend requets are pendin even though i clicked add them. Also, cant send pictures or recieve through messenger.
Install latest yahoo messenger. - if you need assistance getting your computer back on track. Feel free to contact TechieNow:)
SOURCE: Friend list disappeared
Make sure that you have the most up-to-date messenger which can be downloaded here. Sounds like an incompatibility issue between your messenger and your friends.
http://messenger.yahoo.com/
go in the setting and therre will a option of show picture to all my frnds click on this and update ur profile..........then ur picture will shhow
SOURCE: friends' yahoo messenger ID blocked.Can't add it to my msgr list!
I have used Zak's nobuddy before - it has been updated to work with yahoo's newest protocols.
Test: (A) I have 2 yahoo ID's - I added each to the other:
(B) I use Yahoo Messenger version 9.0.0.2162
(C) I was invisible mode at all times on each ID
1 I then got this zak nobuddy to remove one from the other:
2 It worked (although it left no message - I was simply gone).
3 I then performed the normal add request - this too worked fine and I was added again as soon as ID2 accepted.
You say it's blocked from your contact list:
I would check from messengers menu bar
messenger/ preferences/ ignore list and see if your friends ID is in there.
SOURCE: I'm using windows 7.. my yahoo messenger is have a
new virus infection: it can be fixed through deleting extra key in registry settings. navigate to HKEY_CURRENT_USER \Software \Microsoft \Windows \CurrentVersion \Internet Settings\ then delete keys other than 0,1,2,3,4. that extra key may be alphabet "I" or something.. (0-4 is IE default internet zone security setting..) get someone who knows around windows registry to set it right..goodluck
SOURCE: your request to add a
Google it and no satisfactory answer, same problem with us and gives us headache.
