It is in arabic language,how to change to english language
Hi
go to setting on your cellulat
there goto language
there you can change nthe language
bernard
http://www.rylwy.com/
SOURCE: i want to change language arabic to english from
Go to Settings then Phone Settings then Language..
SOURCE: How do i change my language from arabic to english
1. Go to settings option.
2. Check the regional settings option to confirm the country for english language.
3. Then go to Multilingual support, in that check the country option in US english.
4 . Then go to control in Multilingual support and select English with arabic support.
Then restart the set and check the language.
This will work for all 2630's from whatever language it is currently set at to your desired language. Press the center square button to get the menu. Scroll down until you see the small wrench - menu #4. Press the square (Select) button again. Scroll down to #9 - the icon will look like a small phone with a wrench - press select. Press select again - menu #1. Press select again - menu #1. You should be able to see English as an option. Scroll down and select again and you should be good to go. The Nokia menu sequence is: Menu, 4, 9, 1, 1. Unfortunately, this phone does not do jumps - so you must scroll down manually.
SOURCE: How to change my Motorola Razr from Arabic to English?
1. Go to Menu
2. Select the bottom right icon (there will be 9 icons)
3. Select the 6th choice down
4. after that, select the 6th choice down again
5. then, select the first or second choice
SOURCE: how do i change my language from arabic to english
sir how can i convert arabic to english in my i mate jama
