Question about Jamo MPA201 2-Channel Amplifier
Two Jamo MPA-101 amps not working
I picked up a couple of Jamo MPA-101 amps the other day. The Blue power light comes on with both of them but no output. I have removed the covers and checked the only fuse I can find. The fuses on both amps are good. What should I do next? Thanks. Lee Jacobsen 804-462-3246
  • 1 more comment
  • NHTC40D Jan 20, 2009
    I have the same problem. It appears as though it is on, but not sending any power to the speakers. The fuse does not appear to be blown.
  • Anonymous Apr 13, 2009
    same problem, i have two of them and when i switch to the other one the speakers work.
  • Scott Frye
    Scott Frye May 11, 2010
    HI....
    Do you have good speakers connected when you turn them on?
    Are the amps in bridged or stereo mode?
    Here's their link
    http://www.jamo.com/Default.aspx?ID=1424...
  • 4 Answers
I can almost guarantee that you'll find bad electrolytic caps on the power supply board to be the cause of the problem. I've seen several of these with the same problem. The protect circuit stays latched due to excessive ripple.
Posted on Aug 14, 2009
  • John McCutcheon Apr 20, 2012
    So how do I get it fixed?
I replaced all of the caps in the power supply section and it fixed this amp.
I own Spectrum Electronics , 727-289-9746, I work on all makes and models.
Posted on Jun 06, 2012
    Problem Solver:
  • 8 Answers
I'm probably too late. Check to see if your amp is in "Auto" mode, this is automatic turn-on when it sees input.
Posted on Oct 07, 2009
SOURCE:
Where on my mixer should I plug the subwoofer into? Or would plugging it in somewhere else be better ?
This will depend on whether your sub-woofer is powered (has it's own built in amplifier) or not. If it is not powered it will need connecting to an amplifier. If it is powered you will need a line level output either on the amp or the mixer.
Many modern amplifiers (and some mixers) have a dedicated output for sub-woofers in which case this is the best place for it because the higher frequencies will have been filtered out.
Some high quality amplifiers like the JAMO MPA 101 have a filter switch and adjustable filter level for powering sub-woofers. You then just connect the speaker to the speaker terminals in the normal way.
Otherwise on a p.a. mixer you could use the main output, one of the auxiliary, monitor or sub-mix outputs. If you are not using the main output you will need to route signal to the appropriate output accordingly. Either way your output signal will cover the full frequency range - your subwoofer may have built in filtering or you may need to use some sort of crossover to split the signal between the sub-woofer and the rest of your speaker system.
Feb 25, 2011 | Audio Players & Recorders
Amp's blue light is on but does not seem to send power to sub
It is possible that the set has gone into an error shut off. Please disconnect the power and allow it to cool off. remove the sub woofer connections if the amp does not turn on again. check for any short in the coils. reconnect the sources once again , making sure that the source is coming into the amp. If there is still no output, remove the cover and check if the main amp is shutting off due to any short in the output. You will need to confirm this out as you had run this a little too much in heat. replace the shorted mosfets if confirmed. hope you get this right. Good day
Jul 13, 2010 | Pioneer GMD7500M Car Amp
I'm replacing a JAMO amp.
The 201 is 100w in to 4ohms and the 101 is 50w into 4 ohms other then that there the same
Mar 24, 2010 | Jamo MPA201 2-Channel Amplifier
I have a MPA 201 2 channel amplifier that just stopped putting out power, power light is still on, any suggestions?
You need to determine if the power is getting to the audio amp section. For instance with the volume full up is it humming etc?
As a 'rule' it's unlikely that both left and right channels will fail at the same time (unless you have done something silly with the amp) you are looking for something that is common to both channels. Which is why the power section is first suspect. The exception to the rule (above) is where amps use say an IC power amp for both channels. You will find this IC on the big heat sink. Check whatever is on that anyway for damage or burning.
The only other area could be the pre-amp part. Again this could be a single IC controling both channels, so it's failure could cause a loss of sound. By the way if you can hear music/sound coming through when you put it up to full volume the pre-amp will be generaly good.
Nov 16, 2009 | Jamo MPA201 2-Channel Amplifier
Jamo MPA-101 2 channel amp quit working
Check the small electrolytics on the power supply board for high ESR, Very common problem on these amps. Protect circuit stays latched due to high ripple from PS.
Mar 24, 2009 | Jamo MPA201 2-Channel Amplifier
MPA-101 Amplifier powers on, receives source signal, the fuse is not blown inside, but no sound comes out of the amplifier. The amp is pretty new, doesn't even have dust inside the unit.
Hello, is this a Radio Shack PA amp or Jamo amp? The unit is probably in "Protect" mode. Is this a PA system or a receiver...receivers have a protection circuit that will not let the speaker relay activate if the amplifier output section is shorted and sending voltage towards the speakers...so they won't fry!!The speaker relay should activate within 3 to 5 seconds if your output section is ok.
barneyluc
Oct 13, 2008 | Audio Players & Recorders
Monster MPA 5150SS
Might be a failing semiconductor component (usually an old transistor) in the amplifier's front end. This caused by the oxidation through the component legs or pin. I usually touch and move each transistor's body to exaggerate the noise. You can research also what kind of noise is it producing- intermittent, static, etc.
hope this helps..
Sep 20, 2008 | Monster Cable MPA 5150 SS Amplifier
Jamo MPA201 2-Channel Amplifier Logo
2,786 people viewed this question
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
rjivaro
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
