Question about Maytag 24 in. MDBH955AW Built-in Dishwasher
My Maytag MDB7609awb2 dishwasher has a glitch When I try to turn it on the heavy and light was lights go on but won't start the normal wash light won't go on at all until I keep pushing the off and on for a while, then suddenly the normal button works and start will start the machine, then is washes without any problem.
SOURCE:
jsrock516
  • 5911 Answers
SOURCE: maytag dishwasher mdbh950awb
Sounds like you have a control panel and/or control board issue. Normally when operator functions fail or "halfway" work the main control board, associated keypad, or wiring are the likely suspect. Now...another remote possibility could be the door latch not closing properly. However, this would affect ALL functions. I hope this helps you.
Posted on Jul 31, 2007
SOURCE: Maytag MDBH950AWS Dishwasher won't start
We have a Maytag Dishwasher that won't start. The only button that lights up is the "Heavy Wash" cyle. When this button is pressed, the "Heated Dry", "Sanatize" and "Extra Rinse" lights up. The dishwasher doesn't start. Eventually all of the lights go out. the buttons start/cancel do not light up.could you in some way help?
Thank you.
Posted on Dec 28, 2008
SOURCE: dishwasher won't turn on, lock light comes on when I try to start
my husband found the solution on line when he googled the problem. He read that the drain could have been blocked, or it said press the drain button. That did the trick, and now I have clean dishes! He didn't have to pay anyone to solve the problem which was nice.
Posted on Dec 04, 2009
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
Posted on Jan 21, 2010
SOURCE: I have a maytag dishwasher and the light wash light stays on
I have had numerous problems with the conyrol panel on this particular unit. Runs about $95
Posted on May 31, 2010
Maytag mdb7749awb1 won't start
Thank you very much after doing the normal heated dry three times all the lights on the panel lit up and my dishwasher started running
Aug 18, 2012 | Dishwashers
My maytag W10199645 dishwasher won't start
Maytag model w10199645 was starting intermittently, and sometimes only when we pressed and held the start button for 10-15 seconds. Finally tonight it just wouldn't start, period. I unplugged it for 15 minutes, then used the Heated Dry/Normal/Heated Dry/Normal and it started back up on its own.
Mar 23, 2012 | Maytag Dishwashers
MDB7749AWB
Hello I had the same issue the sequence for resetting the panel is;
heated dry...normal...heated dry...normal
all the lights will go on then off. on my machine it started the normal wash cycle. I let it run normally so far this worked.
Hope this helps.
Dec 30, 2011 | Maytag MDB7749AWB Builtin Dishwasher
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Dishwasher won't turn on, lock light comes on when I try to start
Dec 03, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Maytag dishwasher mdbh950awb
Jul 31, 2007 | Maytag 24 in. MDBH950AWS Built-in...
Maytag 24 in. MDBH955AW Built-in Dishwasher Logo
78 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
