Question about Maytag MMV5165 Microwave Oven
Maytag Microwave model MMV5165BA has error E-13
Just installed this new microwave. It works for a while but error 13 comes on after about 3 minutes
  • Maytag Master
  • 9,174 Answers
    New Friend:
The power to the microwave goes off before the required cook time is up. The entire thing goes blank, no clock, no timer, no fan. Nothing works. Finally power restores itself in 20-25 minutes. Very frustrating to have food only 1/2 cooked and be unable to finish it. Is this perhaps a sensor problem??
Posted on Feb 22, 2010
SOURCE:
300 is not 3 minutes on a microwave.
as you stated...microwave counts down in seconds.
300 seconds is 5 minutes 180 is 3 minutes.
Jan 27, 2018 | In Microwave Ovens
I have a Kenmore microwave with an error code SE or 5E model No: 401.80082700
The SE error code means the microwave has had a Key short error. The control panel or smart board will need to be replaced.
Not really a DIY job. Microwaves can retain up to 2200V even when unplugged.
control panel frame assembly ("control") , which comes with a new keypad already installed lists for $59.99 fyi.
Feb 22, 2018 | Microwave Ovens
Emerson microwave mw8781sb
I suggest you return it to the place of purchase for replacement as it obviously is defective
Aug 04, 2013 | Microwave Ovens
Our Sunbeam model SM15A19W over the range microwave quits after 3 - 4 minutes of use and we have to wait 15 minutes and it comes back on. Is there anything I can replace myself?
Had a similar issue I found the unit was overhaeting and if I ran the air vent while in use it helped cool it is this a non-vented system mine is
Sep 03, 2012 | Sunbeam Microwave Ovens
Maytag microwave overheated and shut off - Model #MMV5165BA
That is not good, the magnetron has gone, or the thermal fuse has failed, "protects the magnetron from overheating" There is a possibility the keypad control board was a affected.
Apr 07, 2012 | Maytag MMV5100A Microwave Oven
SE or 5E display on Samsung Model number SMH8165ST
This microwave is a piece of garbage and Samsung are a bunch of idiots. I have a solution but first I will vent. One day after my warranty ran out, I started getting this SE error. They referred me to an authorized repairman, who said it would be $200 just to come and look at it! Thats for a microwave that sold for slightly more than that new! Samsung refuses to offer any do it yourself help. Some guy who works on microwaves told me to order a new control panel. part DE94-01806C It was about 36 dollars and took about 10 minutes to install. If you want to save a little, for 24 dollars you can just replace the membrane. That requires removing the existing membrane with a hair dryer and then carefully applying the new one. Seemed like too much trouble so I went with the control panel.
Feb 04, 2012 | Samsung SMH9151 Microwave Oven
Microwave not working stating error 3 or error sensor or just coming on by itself. we have tried shutting down circut breaker
Hello
"ERR 3" means that the magnetron units have failed in the microwave. Food will not cook or heat up when the microwave is in use.
This code is different than "ERR 1" or "ERR 2" because with those the microwave is still operational. "ERR 3" means a complete failure.
The magnetron is the main source of power and heating in a microwave. Magnets work inside a magnetron tube to create the heat and voltage needed to cook items.
Bring the microwave back to the retailer or a repair shop for service. You may also consider purchasing a whole new microwave if the prices are cheap enough.
Oct 04, 2011 | Microwave Ovens
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
Pasta boat manual
MicrowavePasta Boat InstructionsFor elbow, bowtie, ziti, rotini, and penne
1 serving -1/2cup -water levelat #1
2 servings -1 cup -water level at #1
3 servings - 1 1/2cups - water level 2
4 servings - 2 cups - water level at 4
6 servings - 3 cups - water level at 6
8 servings - 4 cups - water level at 8
cook times based on serving ( serving - minutes)
1 - 17
2 - 18
3 - 21
4 - 23
6 - 25
8 - 27
Stir macaroni once halfway through cooking for al dente; for softer pasta, cookseveral minutes longer.
For spaghetti, linguine, angel hair andfettuccini
1 serving - 1/2 the handle - water level 1
2 servings- 1 full handle - water level 2
3 servings- 1 1/2 handles - water level 3
4 servings- 2 full handles - water level 4
6 servings- 3 full handles - water level 6
8 servings- 4 full handles - water level 8
Cook Time: servings/minutes
spaghetti - 1/13-14, 2/15-16, 3/16-18, 4/18-20, 6/20-22, 8/22
thin pasta-1/12-13, 2/13-14, 3/15-16, 4/17-18, 6/19-20, 8/21
angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17)
Nov 30, 2010 | Microwave Ovens
Maytag MMV5165 Microwave Oven Logo
567 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
