We took out window unit out to clean it. after putting it back in the window the fan is running but compressor won't kick on. it is only a year old and we did wash it.
SOURCE: frigidaire wall unit- 4 years old air conditioner
try a fan run capacitor ,,,and the a new fan ,see if fan is stif to turn by hand if so replace fan
SOURCE: Frigidaire 12000 BTU A/C window unit
The reason that it's doing that is b/c at first its running only with the fan butwhen the compressor clicks on it trips the breaker if you have other items running off that circuit "unplug them" [even turned off items can still consume some power]. Then try to running only the ac unit see if it works a 12000btu takes a lot to run, if this doesn't work the ac may be to much for your circuit to handle and a smaller unit may be needed.
SOURCE: A/C UNIT FANS BLOWS NO COLD AIR COMPRESSOR KICKS ON THEN OFF
check fins in the condenser coils (the fins on the outside part) for obstructions or alot of bent fins. should be free and clear. but chances are the freon level is low. can be serviced, but may be cheaper to replace.
SOURCE: My Frigidaire FAX050S7A window mount a/c unit
Yes they can leak and will need a recharge....just check first that the leak is very small or can be fixed before spending the money to recharge it...with the low cost of window A/C units you can easily get a repair bill for more then a new one would cost...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
SOURCE: I have Frigidaire Thru-the-Wall electronic
As the smell comes only when the Air conditioner is on. The problem is due to the refrigerant inside.May be due to long usage the refrigerant as lost its property.Please drain out all the refrigerant and refill it.You wont get the foul smell problem.
Thank You
Hi - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
When was the last time you cleaned the condensers? You may do so by removing the toe grille and use extended vacuum attachment and condenser cleaning brush to remove dust buildup from condenser coils usually located on the left side underneath. If you hear the compressor running and if it is providing warm air then that means it is operating correctly and the sealed system is removing heat from the cabinet. Fan motor/evaporator may be the primary issue. However, if you do not hear the compressor and the unit is blowing room temperature then the unit may possibly have a sealed system leak, faulty compressor or overload relay. Contact a professional to move forward accurately from this point.
