We have found this company http://www.wirelesspro.com/ for TalkAbout accessories.
Best regards.
SOURCE: Talkabout Motorola T5530
I found the T5000 manual here (It covers the T5000, T5500, T5530 and T5550)
http://www.giantintl.com/RadioPDFs/manuals/T5000.pdf
Semper Fi,
Jstwhln
SOURCE: Will a Motorola TalkAbout T5320 transmit to a Motorola TalkAbout T5530?
Hello Blindmaster,
Check the Continuous Tone Coded Squelch (CTCSS) settings on all the radios. (Note that some manufacturers refer to this feature as a “Privacy Code” or “Quiet Code.” The actual name of the feature may vary.) This feature encodes a low-frequency signal on your radio transmission. This signal is below the range of human hearing but can be detected by other radios. When the CTCSS feature is active your radio will ignore any signal that it receives that does not have the proper tone encoded on it.
In order for these radios to communicate, all of the radios need to be on the same channel and have the same CTCSS code programmed or the CTCSS feature must be disabled.
I suspect that CTCSS is activated on your T5530s but is not enabled on your T5320. This would result in the situation you describe.
Also take note that when using different brands / models of radios to communicate with one another that the CTCSS code numbering scheme may not necessarily be the same from radio to radio. For instance, CTCSS code “4” on the Motorola TalkAbout series actually corresponds to code “A” on the Motorola Sport models.
Best Regards,
Agent Ken
Go Ahead. Use Us.
SOURCE: I have the Motorola T5530
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
You might start by checking the frequency, code and Qt filter (if any), to be certain they are set alike.
Best regards.
SOURCE: The charger for my Motorola
Check with www.wirelesspro.com or the Motorola TalkAbout store http://www.store.motorola.com/b/2952967011
Best regards.
