I forgot the code and i want to unlock it plz. help
Ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If you have forgotten the security code of your Nokia 2310 you can do a master reset to your mobile. this would restore your phone with default factory settings. You can get the master reset to your Nokia 2310 from www.wickedunlock.com at affordable cost. All the best mate.
SOURCE: plz help me unlock my security code..Nokia 6288
hi, i can give you the master code but you need to read this first ok.
1. the master code wont work if you have entered 5 wrong codes as the phone will be hard locked and can only be unlocked using flash lead and unlocking software.
2 the code only works if the phone asks for security code when first swtched on.
If you have not entered 5 wrong codes then this master code will reset the security code and remove it unless you want to put another security code back on the phone.
enter this code when asked for security code ok 4365426660.
This code will only work with your imei number as every single phone has a unique master code based on the imei number ok so double check the imei number before trying the code.
Any problems just give me a shout back ok.
SOURCE: unlock memory card
If your phone is blocked. Take it to your nearest network provider outlet, to get it unblocked.
If your sim card is blocked. Go to your network providers website, where you can obtain the puk code that will unblock the sim card.
SOURCE: Unlock Keyguard code
My Keyguard code forget and IME No. is : 357071006807564 please give me a solution and Model No. : Nokia 1600
SOURCE: Forgot nokia n70 pin code
Get your phone IMEI number which is a fifteen digits number located in the battery compartment of your phone.
Then Visit http://www.nokiamastercode.com
Input the imei number at the site to generate a master reset code which you input when you switch on your phone.
This enables you to reset your phone security code.
Rate this fixya. Good luck.
SOURCE: Forgot unlock code Nokia n82 mobile
send me ur imei no. on
[email protected]
i will provide u secirity code
if u r satisfied pls vote me
