Question about Haier HLP21E Top Load Washer
Haier washer won't start
Hello. ran a wash. tried to do it again. will not start. hit same buttons. nothing. waited 30 min, checked balance of machine. nothing. help!!
  • Anonymous Feb 01, 2008
    My toploading Haier washer is about four years old and has stopped running, although I can hear it click on. First, it started making loud noises. Then, I had to take out half of the wash to get it to agitate and spin, and there was a metal-burning smell, so I knew something was about to go, and now it has gone.
    I'm a senior with a tight budget. Is it something my son can fix? If not, who do you recommened in the Bountiful, Utah area (84010), north of Salt Lake City.
    Thank you
  • Anonymous Mar 16, 2014
    My Haier portable machine wont spin out. The belt is fine. Sometimes it corrects and starts to spin but now won't spin at all. I think it has something to do with a small plastic piece that seems to have a small pulley attached to it. I've adjusted that before and it started to spin. Now nothing.
    Problem Solver:
  • 11 Answers
1. does machine light up on control board? no. check breaker box or try plugging a lamp into the same outlet to see if it works. for this problem you may need a repair man to look at it.
Posted on Mar 22, 2007
SOURCE:
I have a Haier washing machine and the door is locked. I tried washing a blanket and now I can't get the door open. Help!
try unplug the washer an waiting 5 min it should unlock if , if ti does onlock you made need call a appliance servce tech
Mar 05, 2018 | Haier Washing Machines
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
Door won t lock
Check if the program has finished and returned to release. If not the latch wont operate.
Sep 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
When push the start button it will run for a minute and then beep the display window will read f 11
The MCU motor control unit is at fault.
Unplug the washer for 60 seconds.
Plug it back in and try again.
If the fault reoccurs,replace the MCU.
Apr 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I can't change settings and it beeps three times when i hit start button and also don't start
What you need to do, is unplug for 30 mins. Then try it again.. It should reboot itself
Jan 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Elite he3 washer door will not unlock after a FH error
I had the same problem. The manual is useless and hitting the pase/reset button did nothing for me. The wife called the help line and they said they would be out on Monday at $75.00 to check it out. Oh, but the good part is that the $75.00 would go towards the part (if needed). If you forget to turn the water on, and the washer stops working, it seems that it should be smart enough to shut off and continue working when water is put back on.
Anyway, knowing that nothing was broken I decided to pull off the cover. Disconnect the power cord 1st. You ill need a "star" type screwdriver (its a 6 pointed tip). Probably a couple dollars at the local hardware dept. Take the 3 screws off located on the back/top of the cover. Slide the cove back & then pull it off. I then plugged the washer back in. Same humming noise & still locked. I pulled off the connector labeled "D P 21". It is located near the middle of the CPU box and it has 2 black wires coming out from it. You should have the humming noise stop. Wait a few minutes to see if the washer shuts down. If it does then the door will be unlocked. I then had the wife start a new cycle and all is well.
*Note: If you unplug D P 21 and after a few minutes it still doesn't shut off, try pressing the reset button twice and wait again.
Sears can now kiss my **** for wanting to charge me $75.00 for something that was never broken!
Jan 14, 2009 | Kenmore Elite 45986 Front Load Washer
Haier HLP21E Top Load Washer Logo
363 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
