How do you reset this watch? Inside the watch back are instructions as follows: 1. Replace a new battery. 2. USE METAL TWEEZERS TO CONTACT "Reset (RST)" POINTS QUICKLY. 3. If it doesn't work, repeat step 1 & 2 again. I replaced the battery. NOW WHAT!
SOURCE: battery change and then reset
If you open already the watch,and you want to take the old battery,there is a clip that's lock the battery twist that lock.then the battery comes out and replaced with a new one. If you have already put the battery and no display you must reset it by shorting battery connection,in the plate there is arrow guide to the hole where you put your tweezers to short the connection.then the display appears 8888,that is already resetted take the tweezers..
click below for video guide;
G-ShockBattery Change Tutorial
hope this may help
DON'T FORGET TO RATE
Regards,
VOTIT
SOURCE: battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
SOURCE: casio watch problem
Appreciate the direct "Ask Me".
Offhand, I would say yes to the battery replacement. Though watches are not within my immediate field. This would be based on your post "2-5 minutes behind". As to the "lost signal" after a reset, may I request that you post back the specific model number pls.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
SOURCE: Help! I need instruction manual for Fossil watch
If you go to www.fossil.com you can find the manuals for most of their watches.
SOURCE: how to get casio sea-pathfinder working after replacing batteries
got a sea pathfinder and just got it back after sending it away to get batteries replaced. Worked fine for a day or two but now none of the buttons work at all - it is still chugging along keeping the correct time but no buttons including the light works - is there a manual reset procedure without taking the back off?
Cheers
Daz
